Thread: I discovered something interesting
Results 1 to 19 of 19
  1. #1 I discovered something interesting
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    the other day i started doing my header swap, going along no problems until i didnt have a ratchet strap. got the front and crossover off in like an hour and had to stop until i could borrow one and got started again a few hours later. pulled the motor forward and was working on the back stuff when i noticed the windshield plastic cowling was melted in a spot. didnt really think nothing much of it, but the fiberglass on the firewall was pretty much falling off and it was making my itch so i just tore it off. when i did i noticed black scoreing marks like from a fire and then all the pieces fall together. alot of plastic pieces, connectors, plugs, throttle cable are all melted or warped. before i thought that maybe it was something like an electrical surge or a high voltage wire has shorting out on something, but nope. my damn car was in a fire! from the looks of it, it must of been a while back because the metal where the cowling is melted is rusted, and its just a small spot. was there a recall of some sort on these cars for spontaneously bursting into flames? im kinda pissed at the guy who sold me the car for not telling me but maybe he didnt know iether, maybe it happened with the first owner before him but im still none too happy.
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  2. #2 Re: I discovered something interesting
    Omaha, NE
    97-03s were known to catch fire, there were a couple of recalls on the issue.
  3. #3 Re: I discovered something interesting
    Troy OH
    yeah, the valve cover gaskets had a recall on them.
    9047, engine compartment fire.
    at first i think they changed the gaskets, then they just started doing a spark plug rewire or something.
  4. #4 Re: I discovered something interesting
    Wait I thought the fire was in the front not the back of the engine.
  5. #5 Re: I discovered something interesting
    Troy OH
    coulda been driving. a fire's a fire lol
  6. #6 Re: I discovered something interesting
    The recall was replace the VC gaskets AND remove the spark plug wire plastic retainers where they would hold the oil if it leaked out of the VC.
  7. #7 Re: I discovered something interesting
    Nov 2010
    south east AZ
    wow interesting. it seems as if the fire was towards the back of the fire but im only speculating as there are black marks going up the fire wall, a small part of the windshield cowling is melted, and i have all sorts of melted/ warped/ bubbled plastic in the engine bay. also there are two bare spots on my hood which i would also assume was caused by the fire burning the paint off.
    bluegtp...strange you should mention the part of the spark plug wire retainers cuz i still have the front one on
    01 T/A WS6-SOLD
  8. #8 Re: I discovered something interesting
    sounds like this one was on fire and no one reported it then sold it to you.
  9. #9 Re: I discovered something interesting
    Nov 2010
    south east AZ
    ya, f-ing retarded too. if it was a recall then a dealership wouldve repaired all damages right, maybe not the insurance but still you know. from what i can tell though is that it appears to have happened some time ago cuz the spot where the cowling is melted, the metal under that is rusted
    01 T/A WS6-SOLD
  10. #10 Re: I discovered something interesting
    the dealer recall doesnt really help all the time.
    The fuel rail quick disconnect's leak.
    the o-rings compress over time then leak.
    Solution is to replace the quick disconnects with new ones OR replace the entire plastic line with braided stainless and some AN fittings.
  11. #11 Re: I discovered something interesting
    Nov 2010
    south east AZ
    from looking at it, it appears the fuel feed and return line have both been swapped for rubber fuel lines
    01 T/A WS6-SOLD
  12. #12 Re: I discovered something interesting
    Thats bad....
    Are they double clamped?
    If so, theres probably no flare on the pipe.
  13. #13 Re: I discovered something interesting
    Nov 2010
    south east AZ
    no, just single clamp and i think i described that wrong. from the metal feed line as it come up under the brake booster, there is the rubber fuel line that attaches to the fuel rail and same for the return line
    01 T/A WS6-SOLD
  14. #14 Re: I discovered something interesting
    You sure they're rubber? not plastic?
  15. #15 Re: I discovered something interesting
    Nov 2010
    south east AZ
    rubber cuz ive been rubbing my arm on them all afternoon while swapping my headers lol
    01 T/A WS6-SOLD
  16. #16 Re: I discovered something interesting
    Nov 2010
    south east AZ
    so im thinking that maybe they got swapped when the fire happened, dont know.....
    01 T/A WS6-SOLD
  17. #17 Re: I discovered something interesting
    Hmm, i wouldnt leave those rubber unless they've been secured properly at each end.
  18. #18 Re: I discovered something interesting
    Nov 2010
    south east AZ
    i havnt had any problems with them since ive had the car for the 4 months. plus the hoses are attached to the stock metal lines at both ends so they are clamped to flared ends, im not all that concerned with it, if they were rubbing against something i would fix them but they appear to be doing fine, just gunna continue to monitor them
    01 T/A WS6-SOLD
  19. #19 Re: I discovered something interesting
    if they're on flared ends you're good.
  1. interesting to see this wtf
    By imdaman3 in forum Off Topic Discussion
    Last Post: 03-02-2010, 01:07 PM
  2. Had a interesting night
    Last Post: 02-15-2010, 12:49 PM
  3. have some interesting questions
    By JunkboxGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 08:10 AM
  4. Interesting article
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 01-21-2009, 08:06 PM
