Thread: Can the mielage computer be adjusted?
Results 1 to 15 of 15
  1. #1 Can the mielage computer be adjusted?
    Apple Valley, MN
    Hey All,
    I have a GTP (See sig) and am assuming the econ/range/mileage computer is calculating based off of stock hardware... which I do not have. Is there any way to adjust this or reprogram it so that it is accurate with my setup?
    Its no huge deal, but I would love for the range/mpg/fuel used to be accurate. Something though tells me that you can have Accurate or you can have more power...
    Thoughts?
    (edit: Yea, i see I spelled mileage wrong. I was educated in a public school.)
    ‎1998 GTP. ZZP intercooler, 3.1 quickchange Pully, ZZP 8 rib, ZZP Fuel Rails, 42 lb/hr injectors, Thrasher cold air intake, High flow Cat, U-bend delete, Fuel pump hotwire kit, Custom ECU Tune, 180 Tstat, Intake Port-Matched to SC, DynoJet wideband commander, 12" FBody Brakes. 2.8" pully & tunes for 3.1"/E85, and 2.8"/E85
  2. #2 Re: Can the mielage computer be adjusted?
    Pennsylvania
    I'll just pull this out of my ass:
    You'll need to reprogram (with a tuner) whatever it is that reads the wheel speed sensor if you are running wheels/tires that do not equal stock diameter or the diameter has changed since you last tuned it.
    The rest is sensed by your fuel pump's floaty doodad (so that's not wrong) and your O2 sensor... which isn't wrong, either, unless you broke it.
  3. #3 Re: Can the mielage computer be adjusted?
    Apple Valley, MN
    Quote Originally Posted by SlowNA06 View Post
    Tires are stock sizes... I wouldn't think the fuel pump floatie calculated how hard you were pressing on the gas.
    o2 sensor is windeband but read by the ECU correctly.
  4. #4 Re: Can the mielage computer be adjusted?
    Omaha, NE
    For the odometer to be accurate, take it to a dealer and have the BCM read, it should have the actual mileage and a tech 2 should be needed to adjust it.
    If you mean the DIC, do it manually for mpgs.
  5. #5 Re: Can the mielage computer be adjusted?
    Pennsylvania
    Quote Originally Posted by zeeboid View Post
    Nope. It's what tells the gauge how much gas is in the tank. You're looking for throttle position sensor, if I'm not mistaken.
    I'm too stupid to know what you're trying to tell me here. Could you rephrase that, please?
    Hmm, by "hardware," do you mean "injectors?" I don't think that or E85 is going to affect your readings.
  6. #6 Re: Can the mielage computer be adjusted?
    Charles City, IA
    Your talking about the average mpg that shows in the the diver info center right? not the odometer reading. If so It will never be accurate.
    SMGPFC Two Nipple General
  7. #7 Re: Can the mielage computer be adjusted?
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    the floatie doodad would be needed for distance until empty.
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  8. #8 Re: Can the mielage computer be adjusted?
    Apple Valley, MN
    Yes, I'm talking about the driver information center.
  9. #9 Re: Can the mielage computer be adjusted?
    MO
    Will a dealer do that? I thought it was like a felony or something.
    <brandonl2000> LMAO D!!
  10. #10 Re: Can the mielage computer be adjusted?
    Apple Valley, MN
    Quote Originally Posted by ZR1Vette09 View Post
    no no... not adjust the odometer.
    Make the MPG/Fuel Used/Range actually calculate accuratly. After my mods, its all off by about 25%.
  11. #11 Re: Can the mielage computer be adjusted?
    Jul 2008
    sumter,south carolina
    doesnt e85 get worse mileage than regular gas?
    02 GTP with mods 05 GP for DD
  12. #12 Re: Can the mielage computer be adjusted?
    Never Never Land
    ya sinc...and you burn through it a hell of a lot quicker....BUT it's waay cheaper and they said it's like what? 110 octane or something like that. I dont remember exactly.
  13. #13 Re: Can the mielage computer be adjusted?
    Jul 2008
    i think its 106 octane.. and its only like 20-25 cents cheaper than regular gas.
  14. #14 Re: Can the mielage computer be adjusted?
    you're off by 25&#37; because you're running a different fuel than what the vehicle was originally calibrated with.
  15. #15 Re: Can the mielage computer be adjusted?
    Apple Valley, MN
    Sorry, im not actually running the e85 Tune right now...
  1. computer help
    By gtpinsc in forum Off Topic Discussion
    Last Post: 05-22-2010, 01:50 PM
  2. CAI and the computer
    By BigTom73 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2010, 07:57 PM
  3. computer help
    Last Post: 10-21-2009, 09:49 PM
  4. Trip computer
    By SCGTP in forum Audio, Security & Visual Electronics
    Last Post: 07-09-2009, 06:52 PM
  5. Need Computer Help
    Last Post: 04-06-2008, 11:58 PM
