What's stopping you from getting some 97-03 arms? They're identical other than the 97-03 arms having a place to bolt sway bar end links to. I'm going to do this so I can do a larger sway bar on the front.
Hey, you've got a really good point!! :th_thumbsup-wink:
Please do share the results of this as the only point of reference to the differences I have are sketch drawings and part numbers. According to the part numbers below, the *only* difference is the control arm itself. The bushings and ball joint are exactly the same!
019 15293663
W(FE3, FE4) ARM,FRT LWR CONT(INCLS 17,18,20,21)
017 88965333
W STUD,FRT LWR CONT ARM BALL(PART OF 19)
028 10255029
W BUSHING,FRT LWR CONT ARM(FRT)(PART OF 19)
020 10412124
W(FE3, FE4) BUSHING,FRT LWR CONT ARM(PART OF 19)(FRONT)(ACDelco #10412124)
021 10260991
W BUSHING,FRT LWR CONT ARM(REAR)(PART OF 19)
2003 :
026 10328903
W ARM,FRT LWR CONT(INCLS 22,25,28)
022 10260991
W BUSHING,FRT LWR CONT ARM(REAR)(PART OF 26)
025 88965333
W STUD,FRT LWR CONT ARM BALL(PART OF 26)
028 10255029
W BUSHING,FRT LWR CONT ARM(FRT)(PART OF 26)
