Thread: no oil in heads after head gasket change!!!
Results 1 to 4 of 4
parks450 no oil in heads after head... 02-27-2011, 11:56 PM
matt5112 Re: no oil in heads after... 02-28-2011, 12:02 AM
BillBoost37 Re: no oil in heads after... 02-28-2011, 08:04 AM
TheOtherNick Re: no oil in heads after... 02-28-2011, 12:52 PM
  1. #1 no oil in heads after head gasket change!!!
    michigan
    ok guys im stumped, i have a 2002 pontiac grand prix 3100 motor. It had a leaky head gasket so i replaced it. after i put everything together i started her up and not only is it running like crap...... but its not getting oil into the cyliner heads. im pretty sure its not the oil pump seeing its not a common issue and that it was working fine before. im more worried that oil isnt getting to the cylinder heads let alone the rest of the engine. the heads have been rebuilt and milled for flatness and the whole top end has new gaskets. the only thing i dont have hooked up is the EGR valve because i lost the bolt. Any help would be awesome thanks.
  2. #2 Re: no oil in heads after head gasket change!!!
    where are you seeking oil?
  3. #3 Re: no oil in heads after head gasket change!!!
    Longshot..but the rods are in the right places? 3100's have different sized rods depending on location.
  4. #4 Re: no oil in heads after head gasket change!!!
    Charles City, IA
    Well If you dont have the egr hooked up, and did not plug the hole on the intake it will run like crap because of the huge vacuum leak. Oil not getting to the heads im not sure on.
    SMGPFC Two Nipple General
  1. LIM Gasket etc. Anything else to change?
    By GrandPrixGTP1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 09:10 PM
  2. 4T60-E Oil pan gasket and oil filter change
    By Jochen in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 11-03-2010, 07:50 AM
  3. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  4. 2000 Malibu 3.1 LIM gasket change help
    By Liquifire in forum General Tech Discussion
    Last Post: 12-01-2009, 07:51 PM
  5. 3.4 LIM gasket change
    By Damojo2003 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 07-29-2009, 03:55 PM
