Thread: Weird Electrical Issues
Results 1 to 5 of 5
  1. #1 Weird Electrical Issues
    SE Level Member Dabman's Avatar
    Jul 2010
    New York
    Hey guys, hopefully you all can help me out. So this all started when I went to my car and found the battery dead. I had a friend of mine jump it with his car and my horn started honking and the red led on the front dash was blinking. I turned the alarm off my the key fob. I then noticed the interior fan wouldn't respond, it was stuck on 5. I could switch either window, top or bottom fans just fine. I let the car run a good 15 min to let the battery charge. The fans became responcive after 10 minutes or so so I was able to turn them off. I turned the car off, the alarm went off again with lights flashing and everything. I went to turn the car back on and the battery was dead. This is a brand new battery, like duralast gold something. I think it may be the altranator or something? Let me know what you guys think. Thanks.
    03 GT, 35% all around, 5000k HID Fogs, Built-in GPS / Rearview Camera / DVD Player
  2. #2 Re: Weird Electrical Issues
    Kinda sounds like more to me. Sounds like a draw, probably the aftermarket alarm or ...and I'm stretching but the oddball fan thing has me thinking about the ignition switch.
  3. #3 Re: Weird Electrical Issues
    Jul 2010
    New York
    I do not have an aftermarket alarm that I know of. The horn just goes off when I turn it on sometimes. I do have an automatic starter that hasn't been working recentally. Ever scence I got the car I have only been able to select fan levels 3-5. Levels 1 and 2 do not work. I was looking in this forum for a solution and did run across the ignition switch. I do agree that it is probablly a draw from somewhere...Any other thoughts guys?
  4. #4 Re: Weird Electrical Issues
    Ok, aftermarket starter, but no aftermarket alarm?
    gosh..Ive been screwing with cars too much. I'm starting to pick on aftermarket stuff as causes nearly as a first rule. lol
  5. #5 Re: Weird Electrical Issues
    Jul 2010
    New York
    Just took it to Autozone to have them test the battery. Battery seemed charged which means the altranater works just fine. I started it just fine and the guy said it sounded like there might be a problem with the starter. He said it could have been that that drained the battery. I will keep you all updated.
  1. electrical issues
    By toastisdead in forum Audio, Security & Visual Electronics
    Last Post: 12-30-2012, 10:44 PM
  2. Weird electrical/transmission/stall issues
    By Perry125 in forum General Tech Discussion
    Last Post: 09-19-2010, 10:16 AM
  3. Electrical Issues.
    By Machzzzz1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2010, 11:59 AM
  4. weird electrical issue oil light on with key off !FIXED!
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2010, 04:58 PM
  5. Help please!!! Electrical system acting weird, Car won't start now!!
    By Tkuligowski in forum General Tech Discussion
    Last Post: 01-24-2008, 08:42 PM
