Thread: car revs like crazy after I removed throttle body
Results 1 to 8 of 8
  1. #1 car revs like crazy after I removed throttle body
    il
    I just changed out the thermostat in a 03 Grand Prix 3100. When I put it back together it was chugging and dying. I took apart the intake and throttle body and cleaned the crap out of it. The car no longer dies but it revs randomly and the RPMs will stick at a certain point like 3k or 4k and jump around. The car does this when sensor number 4 from the picture is unplugged (i'm assuming its the throttle position sensor) and also when number 3 is unplugged (i'm assuming its the mass airflow sensor). Anyone know what the problem could be. Also if you could explain the numbered sensors in the picture it would help.
  2. #2 Re: car revs like crazy after I removed throttle body
    Texas
    1. Looks like the MAF
    2. Looks like IAT
    3 and 4 I need to see a closer pic.
    One will be TPS and I believe the other is IAC
    Hard to tell in the pics for sure, hopefully someone else can help identify.
    85 Corvette
    01 TA
    03 Z06
  3. #3 Re: car revs like crazy after I removed throttle body
    Texas
    Are you sure the intake manifold isn't leaking from not sealing right thus creating a decent size vac leak?
    85 Corvette
    01 TA
    03 Z06
  4. #4 Re: car revs like crazy after I removed throttle body
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    You probably didn't put that vacuum line back on the front of the TB, or it has a crack in the hose. I did that once after putting my tb back on and My car would Idle at like 2 grand.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  5. #5 Re: car revs like crazy after I removed throttle body
    Wichita
    If you reused your TB gasket then that is your problem.
  6. #6 Re: car revs like crazy after I removed throttle body
    il
    Ya I reused the TB gasket, looks to be in good shape. So this could be caused by air leaking out of the system?
  7. #7 Re: car revs like crazy after I removed throttle body
    Those gaskets aren't reusable if they are anything like any typical gasket.
    A new one is a few bucks...go get it.
  8. #8 Re: car revs like crazy after I removed throttle body
    GT Level Member taman86's Avatar
    Nov 2010
    south east AZ
    vacuum leak fo sho, listen for a hissing or whisteling noise
    01 T/A WS6-SOLD
    97 grand prix gtp- flowmaster mufflers, short ram intake, SD headers (no cat), EGR delete, 160* stat, solid motor mount, AL 606's, ported TB, new coils,lifetime warranty plug wires
    BoostnBlackGTP>"Wbody's r cheap to do up and fix but break down alot lol"
  1. N* throttle body
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-21-2009, 01:41 PM
