Thread: Replacement window trim?
Results 1 to 8 of 8
  1. #1 Replacement window trim?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    Anyone know where to get replacement window trim or atleast the part number for it? I am looking for the shiney black part right above the red paint. Thanks
  2. #2 Re: Replacement window trim?
    Apr 2012
    North Dakota
    i am also looking for this but all the pieces around the windows. the dumb*** that had the car before me gorilla glued the window visors on.
  3. #3 Re: Replacement window trim?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    maybe a junkyard
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  4. #4 Re: Replacement window trim?
    Oct 2011
    huntley
    Yea my drivers door got f'ed when I went through a car wash to get the salt off my car so now I am trying to replace all of them. I don't really want to paint them because I think that looks bad and I might have to go to a junk yard if worse comes to worse
  5. #5 Re: Replacement window trim?
    Jun 2012
    Illinois
    You never know till you see what they have there
  6. #6 Re: Replacement window trim?
    dealership sadly is the only place to get them "new". or a parts distributor that sells A/C delco parts may have it.
  7. #7 Re: Replacement window trim?
    Oct 2011
    huntley
    Why do you say "new"? Are they just refinished ones?
  8. #8 Re: Replacement window trim?
    dealerships only sell "new parts" refurbished does not exist for trim parts.
    you may fine nice used parts in the junk yards, but thats hit or miss.
    on the other hand, i re painted mine. took all 4 off, (4 door) cut and sanded off the plastic on the trim. and gave them like 4 coats of black paint and 3 coats of clear. wet sanded and then buffed with rubbing compound.
    granted, they dont look as good as new, but they were free to re paint, and no ones getting cut anymore.
    these are easy to get off too. open the door, inside there's one small screw, take it off, then loosen up the side view mirror. 3 nuts, behind the triangle by the mirror on the inside of the door. then lift the side that had the screw up some, and pull it back till it clears the mirror.
    after pic of re painted trim.
  1. Window trim
    By hockeybawler in forum Visual/Body Modifications
    Last Post: 07-25-2012, 12:14 PM
  2. Door/Window trim
    By MBruneaux in forum Visual/Body Modifications
    Last Post: 06-05-2012, 10:53 PM
  3. Window trim
    Last Post: 04-17-2012, 11:37 PM
  4. window switch trim
    By kingd44 in forum The Rant Forum
    Last Post: 03-23-2008, 08:38 PM
