Thread: leaking moonroof switch?
Results 1 to 5 of 5
99prixgt leaking moonroof switch? 06-15-2008, 12:53 AM
Sabrewings Re: leaking moonroof switch? 06-15-2008, 01:07 AM
99prixgt Re: leaking moonroof switch? 06-15-2008, 03:44 PM
JoshMcMadMac Re: leaking moonroof switch? 06-16-2008, 07:38 AM
99prixgt Re: leaking moonroof switch? 06-16-2008, 02:57 PM
  1. #1 leaking moonroof switch?
    Jersey
    well i was driving today while it was pooring rain and i started to feel a drip on my arm i was like wtf? and i looked up and saw my sunroof button on the headliner was leaking. any ideas how to fix it? or anyone else with the same problem?
  2. #2 Re: leaking moonroof switch?
    Barksdale AFB, LA
    Clogged sunroof drain tubes.
    2009 Subaru Impreza WRX STI
  3. #3 Re: leaking moonroof switch?
    Jersey
    Quote Originally Posted by Sabrewings View Post
    thanx for the reply, if u dont mind me asking is their an easy way to un clog the drain tubes?
  4. #4 Re: leaking moonroof switch?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by 99prixgt View Post
    I have never done it on this car, but on a different vehicle I have had good luck with using compressed air, using the rubber tip pressed tight against the sunroof opening of the drain tubes.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: leaking moonroof switch?
    Jersey
    ill have to give it a shot, thanx
  1. Leaking roof
    By Hobbes666 in forum General Tech Discussion
    Last Post: 09-28-2010, 09:04 PM
  2. Gasket/Leaking problem
    By Phil_GTP in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:48 PM
  3. leaking coolant
    By rdicarlo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 10:04 AM
  4. tranny leaking.....
    By badgtp2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2008, 03:38 PM
  5. Leaking Antifreeze
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 08:13 PM
