lets here ideas
ive heard putting cpu fans in compartement (not sure if it would do anything) just something i read
i was thinkin about making my own hood scoops. pretty good fabricator and welder
lets here ideas
I dont think computer fans would be much of anything, kind of like you flapping your hands to create wind to keep your bedroom cool... when there's already a much bigger fan running. The engine bay is too big for them to make any difference, they'd just be swirling around the hot air that the rad fans are already blowing, or the air that's rushing in at highway speeds.
Modding the hood is probably the best way to go, scoops on the leading edge for fresh air to come in, and some openings on the end closer to the windshield for hot air on the top of the engine bay to be pushed out.
OR just take the hood off all together!
‪GTP Supercharger Whine‬‏ - YouTube
One simple thing is to pull off the gasket at the back of the hood.
I have also heard of people raising the back of the hood slightly to allow hot air to escape. But that is pretty ricer.
Has anyone collected hard data on that gasket being a legitimate improvement?
You should find out where the pressure differential and temps are, then install vents there.
temps = thermal probes on bottom of hood.
pressure, 2" of string taped every couple inches on the top.
Drive 35-40 mph+ and see where it stands up.
Find the best area to place the vents, and start cutting.
No matter what it'll look terrible imo.
Hm, just found my digital thermometer/probe setup a couple weeks back. Guess I need to find some free time.
Insulate the engine....that will keep underhood temps down. Baaaahaaaahaahahahaaha.
Most important is the intake air temperature (hot as possible for fuel economy, cold for power) and electrical items. Sadly the radiators' hot air is directed at the engine.
is it illegal to drive without a hood?
No, but its a bad idea due to it messing with crumple zones.
CO2 would not be a good idea since its non flammable and would displace oxygen in the engine.
wut about changing out the fog lights for air ducts going the bay,, or if your super race make the ducts go to the brakes for cooling
