Thread: 2002 GTP replacement cat question
Results 1 to 18 of 18
  1. #1 2002 GTP replacement cat question
    Indianapolis
    Hey all, I had another more general thread posted about my car a couple of weeks ago, so if this is spamming please merge them.
    My car (2002 GTP) is setting a catalytic converter code and the SES light is on. Replaced rear O2 hoping that was the problem and the code went away but came back on about a day later. Mechanic is pretty sure the cat needs replaced, so before I order one I want to make sure I do it right.
    Will this cat be a suitable replacement for the factory cat, and will it operate properly with the stock emissions control and not cause more codes to pop up? ZZ Performance Was going to go with the ceramic core as I believe it's what's currently in there but not positive.
    Also going to replace the upstream O2 sensor just to be safe and get it all out of the way now. Any advice would be great, just want to make sure I don't screw it up.
  2. #2 Re: 2002 GTP replacement cat question
    Donating Users
    South Deerfield, MA
    The Magnaflow high flow cat from ZZP kicked a P0420 code on mine.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: 2002 GTP replacement cat question
    Jul 2008
    sumter,south carolina
    if u dont plan on any modding down the road... id spend the few extra dollars and get a 3 in downpipe. its a cheap mod that has u bend delete and will give a u little more power. there is a chance with having a hi flow cat either way that it will set a p0420 code. some do it and some dont.
    http://www.zzperformance.com/grand_p...=551&catid=110
    02 GTP with mods 05 GP for DD
  4. #4 Re: 2002 GTP replacement cat question
    Indianapolis
    Thanks for the responses. I will probably do the 3 inch downpipe/cat assembly both now that you mention it gtpsinc. If the car continues to set a P0420 code isn't that going to screw gas mileage? That code is a result of the emissions computer getting an improper fuel/air mix reading on the exhaust right? Won't that result in the computer leaning the car out or richening it up until it gets the right post combustion mix, or am I being stupid about this?
  5. #5 Re: 2002 GTP replacement cat question
    Jul 2008
    youll be fine.. if the light bothers u that much u can always get someone with a tuner to set the code to non report. the front o2 is the important one. i have no cat at all and i get killer gas mileage.
  6. #6 Re: 2002 GTP replacement cat question
    Indianapolis
    Alright that makes me feel more confident then. Much appreciated on the thoughtful replies, and I'll have pics of the car up as soon as weather improves. Hate Indiana winters. It was 70 two days ago and yesterday woke up to 3 inches of snow. Argh.
  7. #7 Re: 2002 GTP replacement cat question
    I can get you the part numbers for some good magnaflow cats.
    They're under $100 yet they wont through a P0420.
  8. #8 Re: 2002 GTP replacement cat question
    Indianapolis
    That would be great CG. Save me the trouble of having to reprogram the PCM.
  9. #9 Re: 2002 GTP replacement cat question
    I'd suggest getting a 3" DP from a vendor.
    Better fuel mileage and a little more go.
    Also welding onto rusted pipes doesnt work well.
    Here are the ones for 3" pipes:
    MagnaFlow Catalytic Converters - 49-STATE & CANADA Catalytic Converters For Trucks, Suv's, American Muscle, Diesel, & Sport Compact Vehicles
    And if you want something smaller you can try this:
    Just to give you an example of how inexpensive they are:
    Amazon.com: Magnaflow 99009HM Universal Catalytic Converter (Non CARB compliant): Automotive
    With ZZP be sure to select the offroad pipe and select the add rear O2 bung for off road pipe.
  10. #10 Re: 2002 GTP replacement cat question
    Indianapolis
    Cool thanks a lot for the links bud. Will update on how things turn out.
  11. #11 Re: 2002 GTP replacement cat question
    I would look into getting it replace for free, iirc certain years of the gp are covered under a manufacturers warranty up to 120k miles for the cats. I do not remember the specific details on it but I got mine done for free.
  12. #12 Re: 2002 GTP replacement cat question
    Indianapolis
    The car has 150,000 on it and I'm not sure if/when the previous owner did anything with it's current cat. Not sure how to find out either as I'm pretty sure the carfax info is long gone now.
  13. #13 Re: 2002 GTP replacement cat question
    Indianapolis
    So I purchased a ZZP Cat and took it to the shop to have it installed, and the mechanic told me that he was afraid that it would rub on the heatshield under the car. He showed me how it fit and there was less than 1/4 inch of clearance on either side of it. It looked like one of these Amazon.com: Magnaflow 99009HM Universal Catalytic Converter (Non CARB compliant): Automotive but was from ZZP. I didn't put it on just because I didn't want to find out the hard way. What am I missing?
  14. #14 Re: 2002 GTP replacement cat question
    you could bend the heatshield so you have more room.
    or buy one of the spun metallic cats.
    If you can wiggle it back and forth and it doesnt hit you're okay.
  15. #15 Re: 2002 GTP replacement cat question
    Charles City, IA
    .25 in on the sides is plenty of room. And yes just bend the heat shield.
    SMGPFC Two Nipple General
  16. #16 Re: 2002 GTP replacement cat question
    you know what i did with my heat shield? cut off wheel. i took it off completely. you dont need it.
  17. #17 Re: 2002 GTP replacement cat question
    Charles City, IA
    I use mine to tuck the wide band wiring up in it.
  18. #18 Re: 2002 GTP replacement cat question
    i used small pieces of the shield that i left still riveted to the bottom side of the car for that. zip ties!
  1. Ignition Switch Replacement Question
    By r1rider in forum General Tech Discussion
    Last Post: 08-21-2010, 03:27 PM
  2. timing chain replacement question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2010, 08:53 PM
  3. Replacement Headlamp Units on 2002 GT
    By cprher in forum General Tech Discussion
    Last Post: 02-05-2010, 09:46 PM
  4. Wheel Bearing Replacement. Question!
    By brownb66 in forum General Tech Discussion
    Last Post: 11-11-2009, 12:04 PM
  5. Belt replacement Question
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 12:00 PM
