Thread: Coolant problems
Results 1 to 2 of 2
  1. #1 Coolant problems
    Grand Rapids
    i've had my 99 gtp for 7 months now. car overheated when i bought it so i changed the hose on it and filled it with coolant. haven't had a problem since then until this week. Low Coolant light came on so i filled it with 2 days ago. but the warning light is still on and my temp on my dashboard still gets up to 185-190 degrees. i'm positive there's no leak because it's still full. not sure what to do with it now. help out?
    i drive 80 miles everyday for work so i'm pretty worried
  2. #2 Re: Coolant problems
    St. Louis
    Do you still have the orange Dexcool in it?
    Pull the oil cap off and look for signs of coolant in the oil (will look muddy brown/yellow). If you see this stop driving it and replace the LIM gaskets before you toast the motor.
    If you don't see any signs of coolant in the oil then I would suspect a leaking radiator or hose. Since the side tanks on these are plastic they will leak eventually. Went through this on my GT. Mine cracked around the upper hose on the drivers side neck. Would only leak when hot and took forever to find.
    That temp sounds about right as I believe the GTP's had a 195 T-stat in them stock.
    Could also be a bad coolant level sensor. This is located on the passenger side of the rad. under the top transmission line. Should have a square back on it with a wire connection to it. You can try removing it (yes, you will loose coolant) and cleaning it. Or just replace it altogether since its 12 years old. You may have to remove the battery to get to it, can't remember for sure. I know its in a tight space.
  1. low coolant light...but not so much low coolant..?..
    By 1lilcountrygrl in forum General Tech Discussion
    Last Post: 08-08-2010, 12:29 PM
  2. Transmission/ Coolant Flush Question and Problems
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 07-17-2009, 03:03 PM
  3. coolant fan problems
    By jpopdallas in forum General Tech Discussion
    Last Post: 04-16-2009, 04:32 AM
  4. Shift Interlock Problem & Coolant Gauge Problems
    By 98GTPON22s in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-26-2009, 04:02 PM
  5. Vehicle problems - won't run, coolant leak
    By boogsey in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-17-2008, 10:17 AM
