Thread: Clearing "Service Engine soon" light
Results 1 to 20 of 22
  1. #1 Clearing "Service Engine soon" light
    Aug 2012
    Wyoming
    New to the forum, not seeing how to search for related posts as I am sure there are some out there on this topic. Becoming rather frustrated with my 05 Grand Prix. I have an OBD II tester and was receiving fault codes for my before cat o2 sensor. I replaced both o2 sensors and did a tune up with new spark plugs, wires, thermastat and a coolant flush. Cleared check engine with my OBD and removed my (-) from my battery for a few minutes as I have read this is how to reset Service Engine Soon. The light still comes on. I was also reading any light bulb being burned out on the car would throw this code. I have no bulbs at all burnt out and the car is running fine. Any help would be great. Seriously sick of having to reset this every single time I start my car.
  2. #2 Re: Clearing "Service Engine soon" light
    Yoga city
    what are the exact codes, may help point some ppl in a better direction
  3. #3 Re: Clearing "Service Engine soon" light
    I live here. TLSheff's Avatar
    What is the actual code showing on the scanner? Pxxxx?
  4. #4 Re: Clearing "Service Engine soon" light
    Jan 1970
    Maquoketa, Iowa
    Do you have a CAT still? Are you sure you have the correct 02 sensors in each spot?
  5. #5 Re: Clearing "Service Engine soon" light
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    DON'T disconnect your negative battery cable. If you cleared it with the scanner the code is gone. At least until something goes wrong again and triggers it to come on.
    I went NA when a whore left -$300 in my bank account.
  6. #6 Re: Clearing "Service Engine soon" light
    Aug 2012
    Wyoming
    I cleared the codes with my scanner and drove it 1st. The car has no codes at all after 100 miles. I was getting 2 codes 1. P0141 and 2. P0054
  7. #7 Re: Clearing "Service Engine soon" light
    Aug 2012
    Wyoming
    Yes, I still have my CAT and I got the o2 sensors at Autozone so they are correct as well. To clarify, I am not getting check engine anymore, just "service engine soon" every time I start it.
  8. #8 Re: Clearing "Service Engine soon" light
    Is this when you turn the key to on, before you actually start the car?
    If yes, that is just showing you that the light works. It's normal. Like the airbag etc lights.
  9. #9 Re: Clearing "Service Engine soon" light
    "service" as in oil change?
  10. #10 Re: Clearing "Service Engine soon" light
    Aug 2012
    Wyoming
    It is the "SERVICE ENGINE SOON" that comes up where the mileage is not the oil. It comes on when the key is in the on position then again when I start the car.
  11. #11 Re: Clearing "Service Engine soon" light
    Nov 2008
    Central NJ
    If the light stays on after you start your car and while it is running, then you might have something to look into. If the light goes out after a few second of starting your car, then it should be OK and there doesn't sound like there is a problem.
  12. #12 Re: Clearing "Service Engine soon" light
    Aug 2012
    Wyoming
    I push the center button on the message system and it goes away. I know there isn't a problem it is just super annoying and I'm tired of it every time I start the car.
  13. #13 Re: Clearing "Service Engine soon" light
    Pennsylvania
    Quote Originally Posted by bvdogg View Post
    So it's on your DIC? Not the instrument cluster?
    Sport Edition Kv5 18x8
  14. #14 Re: Clearing "Service Engine soon" light
    Am i the only one confused by this thread?
  15. #15 Re: Clearing "Service Engine soon" light
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Nope!! Are there codes now? If so what are they!!
    Take 2 and get back to us in the morning!!
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  16. #16 Re: Clearing "Service Engine soon" light
    Aug 2012
    Wyoming
    Not sure how you are confused. The message center that displays the mileage on my car, when I turn the key to the ON position and let it cycle I get "SERVICE ENGINE SOON" audible warning and displays in the message center. Same thing happens when the car is started. OBD II plugged in and cleared all codes that I mentioned above and non have come back on. NOT a CHECK ENGINE LIGHT!
  17. #17 Re: Clearing "Service Engine soon" light
    Ok so you cleared the codes, don't have a SES Light on the cluster, don't have any codes re-appearing... but the DIC is saying Check Engine... sounds like a mechanical error in the DIC. But I could be wrong, electronics in these 04+ can get a little wild.
  18. #18 Re: Clearing "Service Engine soon" light
    new cars and trucks have this info center crap, my 03 gmc had this "reduced power" in the miles area of the cluster, and it also would not do more than idle when it happened, the cel light never came on, took it to the dealer as it was under warranty still, and it was a bad maf sensor. yet the cel never came on.
    so id try resetting everything by taking off the battery and see what happens from there. the dic may need a reset and the scanner wont do it?
  19. #19 Re: Clearing "Service Engine soon" light
    Aug 2012
    Wyoming
    Again, its SERVICE ENGINGE NOT CHECK ENGINE! My OBD scanner cleared my codes I had for my o2 sensors. Done that more than a week ago now and the check engine light is still off just like it was. The message center displays SERVICE ENGINE SOON when the car is started or put in the on position as I have said 4x's now.
  20. #20 Re: Clearing "Service Engine soon" light
    Nov 2009
    A little late
    Could this be as simple as an oil life monitor that needs reset? On an 03 turn key to run, but do not start. Push accelerator 3 times in 5 sec or something, then turn key back to off.
    Maybe post a pic, still confused here.
  1. Replies: 2
    Last Post: 07-21-2012, 08:35 PM
  2. how to remove "Service Tire Monitor System"
    By 04GT in forum 04+ Specifics
    Last Post: 12-20-2011, 10:13 AM
  3. 97 Grand Prix GT "check tire pressure" light on
    By fju2 in forum General Tech Discussion
    Last Post: 08-04-2011, 07:37 PM
  4. Service "vehicle" soon, trac off and ABS light all on
    By 98RegalGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2011, 10:45 PM
  5. "half" light tinting expiriment. looks cool. check it out.
    By colindunn in forum Visual/Body Modifications
    Last Post: 06-30-2010, 08:18 AM
