Thread: Low Voltage
Results 1 to 2 of 2
  1. #1 Low Voltage
    SE Level Member Wakeboy1337's Avatar
    Dec 2010
    Fort Pierce, Florida, United States
    It seems that all of the sudden today I have a voltage problem in my 01 GTP. I Checked the power distribution box, alternator, and battery terminals. I want to check the connections at the starter itself but I can even see them from under the car. Anywhere else I can check besides there? I'm goign to try and wiggle my hand up in there to tighten them but where else could I check? I dont even know where all the grounds are in this car.
    Oh yeah, what's happening...
    When I turn the key to on, the fuel pump barely runs and all of the dash lights are very dim, and of course if I turn the key to start all I get is a single click of the starter relay and everything goes black till I let go of the key. After I've let go the door locks go UNLOCK UNLOCK by themselves. The voltage at the battery is 12.3 volts. The voltage at the Fuse box is also fine with the volt meter. I dont have the slightest clue as to what happened all of the sudden.
  2. #2 Re: Low Voltage
    you could check the positive wire to the starter,( the connection could be bad or a bad cable) and test the alternator, it should be charging over 13 volts, but not higher than 14.
    or maybe the starter or the its self could be bad.
  1. Voltage problem?
    By Dallasneon in forum General Tech Discussion
    Last Post: 07-13-2013, 09:32 AM
  2. voltage booster
    By bps02gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2011, 08:59 AM
  3. Bad voltage regulator?
    By jokyfo in forum General Tech Discussion
    Last Post: 01-12-2011, 12:12 PM
  4. Low Voltage Light
    By GreenPrix99 in forum General Tech Discussion
    Last Post: 12-11-2009, 10:12 PM
  5. voltage fluctuations DIC
    By ghostgt in forum General Tech Discussion
    Last Post: 10-31-2008, 10:15 PM
