Thread: Large Exhaust leak, Most likely place?
Results 1 to 10 of 10
  1. #1 Large Exhaust leak, Most likely place?
    Delaware, OH
    Sea Foamed the car earlier before doing some maintanence (oil, vaccum lines, fluid top off), and while drawing it in through the LIM I noticed quite a bit of smoke coming from the back manifold area. I noticed it on the front back part. So my question is, where's it more likely to leak from back there? Crossover, EGR, manifold?
    Also have a 3 inch downpipe and thats it for the exhaust.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  2. #2 Re: Large Exhaust leak, Most likely place?
    sounds like it's at the manifold to DP connection.
  3. #3 Re: Large Exhaust leak, Most likely place?
    sure it was an exhaust leak? sounds like oil dripping on the rear manifold from the rear valve cover...
  4. #4 Re: Large Exhaust leak, Most likely place?
    Delaware, OH
    Nope. I could see the DP/manifold connection and it was all clear. Smoke was concentrated around the corner section of the engine where the crossover/EGR and manifold edge are.
    Yeah. never smoked there any other time except while drawing the sea foam in. Valve cover edges and heads are still pretty clean from when I cleaned them off while the engine was out of the car for a trans rebuild.
    No More GTP for me.
  5. #5 Re: Large Exhaust leak, Most likely place?
    Kinda sounds like you know where it's coming from. That's where the leak will be if that's where you saw it.
    I said what I did, based on your description in your post. I'm confused as to why you are asking us, if you saw the exact location of the smoke pouring out.
  6. #6 Re: Large Exhaust leak, Most likely place?
    Maybe a leaky EGR instead?
    Just a thought.
  7. #7 Re: Large Exhaust leak, Most likely place?
    Delaware, OH
    Not sure exactly which I need to correct. Whehter it's the crossover, EGR, or the manifold gasket itself?
    Which of those are the usual culprit?
    No More GTP for me.
  8. #8 Re: Large Exhaust leak, Most likely place?
    None actually.. unless you've pulled one of them apart.
    which is another reason why when you said you swapped DP that i was on that gasket.
  9. #9 Re: Large Exhaust leak, Most likely place?
    Delaware, OH
    Gotcha. I'm debating if I want to throw speed daddy's on the car or not. It won't be till I get my tax return so I'll just worry about the leak then I guess.
    No More GTP for me.
  10. #10 Re: Large Exhaust leak, Most likely place?
    That's not the best plan. You should take a moment and look for the leak. Look at it, move your hand around when the engine is cold but running to try and locate it. Fix the leak, it can cause many other problems that you don't need.
  1. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  2. exhaust leak
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 10:31 AM
  3. Need help with an exhaust leak
    By thenervemann in forum General Tech Discussion
    Last Post: 04-26-2009, 09:28 PM
  4. Large EVAP LEAK and FUEL CAP LEAKING?????
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 12:55 PM
  5. HELP! FP leak at large quick disconnect!?!
    By alacran in forum General Tech Discussion
    Last Post: 07-24-2008, 01:01 PM
