Original owner - 97 GTP - 210K - new tranny @ 175K - everything else has been electrical
57k
72k when purchased in July '10
82k now.....
59k on mine.
almost 70k had 58k on it when i got it in march..the one thing i hate about the 97-03 gps is you have to stare at the miles add up while you drive it id much prefer it not be in your face all the time like the newer ones
205k On mine
97 gtp-145k 3rd owner
'00 GT at about 112k. Got her at 77k with a bad TCC for cheap back in '06.
Had a 1997 GTP with 207,000 miles when i got rid of it in 2006,
and the 2004 GTP just rolled over 119,000 the other day.
My ex's 98 GT had 224,000(or close) on it and it was stock engine and tranny. Both ran fine. I was driven alot on the highway where she would put 100+ miles a day on it(sometimes more) I did 99% of the maintenance making sure oil was changed every 10,000 miles(used amsoil rated for like 30,000miles), tranny fluid and filter changed every 45000-50000, and coolant flushed every 50,000. Other than that just your basic parts going bad.
I have a 96 gp se with 125XXX on the orignal trans and about 8000 on rebuilt motor. everybody i have talked to said that the bodies will go before the motor or trans will. i rebuilt the engin bc of cam shaft bearing. other than that no major issue. (knock on wood)
130k on trans And motor and 254k on body super charger has 2'000miles
my 02 has less than my 05.. that is all.
123,xxx on my 07.
Those miles are all from the original owner. They drove around 100 miles a day to and from work. I just got the car 2 weeks ago.
144444 on my 2000 as we speak
Just under 260k miles on my '98. Transmission was replaced at 26k miles under warranty.
At the last Buick Factory 36 reunion in Flint, MI (where the 3800's were built) several people had over 400,000 miles on their motors with no re-builds.
I got 212,xxx. And its still running good. only needs a new crankshaft sensor
The antiquated mechanical odo in my 2003 GTP has about 165k KM's.
I will weep when it hits 2oo ooo.
