Thread: All fed up. And stalled.
Results 1 to 5 of 5
  1. #1 All fed up. And stalled.
    SE Level Member rusty prix's Avatar
    Minnesota
    2000 Prix GT. Stock L36 engine. Car has been running totally normal until yesterday I went to start it and it ran for 4 seconds and then stalled. It doesnt matter if you leave it at idle or play with the gas it stalls after a few seconds even if you do it consecutively. I have unplugged the MAF and it doesnt change anything. Popped the vacuum line off and no gas so the reg must be fine. I read about the bypass for the resistor but I think thats only for the GTP? I havent checked the PCV yet but im not sure if that matters either? I just need some help because im pretty noob at this but I want to learn how to fix s*** like this cause im no rich guy. If anybody could help me out that would be great!
  2. #2 Re: All fed up. And stalled.
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    I'm having the same problem. Have you tried replacing the fuel filter?
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  3. #3 Re: All fed up. And stalled.
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Sounds like a security issue. Starting up and running for a few sec is usually related to that. Esp if it starts up and runs fine for a few sec
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: All fed up. And stalled.
    Minnesota
    No the filter is pretty new still. But does it still sound like security if i reset the comp and it runs fine now? I dont feel like that is a permanent fix...
  5. #5 Re: All fed up. And stalled.
    Willoughby, Ohio
    CPS, crank position sensor, could be bad. stalling with no codes and no warning are nice signs
  1. car stalled
    By GTP514 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2011, 02:55 PM
  2. almost stalled
    By GTPgurl in forum General Tech Discussion
    Last Post: 01-07-2011, 09:17 AM
