Thread: 2000 GP wheel bearing
Results 1 to 12 of 12
  1. #1 2000 GP wheel bearing
    massachusetts
    Whats involved in changing a r/f wheel bearing on a 2000 gp? Trying to decide whether to do it myself or not. Thanks.
  2. #2 Re: 2000 GP wheel bearing
    Pull wheel
    Pull rotor
    Remove axle nut (34/36mm)
    Remove three bolts from back 1/2"/13mm (typically the toughest part of the job)
    Unhook electrical connector
    Remove hub from knuckle and replace with new.
    Going to be doing a couple on Shaggy's car tomorrow night. If we don't already have a write up, we can document it.
  3. #3 Re: 2000 GP wheel bearing
    SE Level Member 02 35thLE's Avatar
    ankeny ia
    If the axle comes out of the hub and the hub comes out of the knuckle ok then it's not that bad of a job to do.
  4. #4 Re: 2000 GP wheel bearing
    The axle stays in .. the hub sits on the axle in teh knuckle.
  5. #5 Re: 2000 GP wheel bearing
    ankeny ia
    Yes the axle stays in the car but as long as it's not rusted in the hub and the hub not rusted in the knuckle than its easy. I just did both my fronts and one axle was so rusted in that I soaked it for 4 days and still had a heck of a time getting it free from the hub.
  6. #6 Re: 2000 GP wheel bearing
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    Pull wheel
    Pull rotor
    hardest part imo is getting the damn hub off the car.
    the three bolts in the back come off like butter..
  7. #7 Re: 2000 GP wheel bearing
    Think I misread your first post the first time through.
    The bolts are usually the struggle for most people. The hub likes to corrode to the knuckle and stiick a bit. I typically just smack it around with a BFH and it's out. Afterall..it's being changed out.
  8. #8 Re: 2000 GP wheel bearing
    GT Level Member sic6's Avatar
    san marcos, tx
    Here is a good video on how to replace the hub bearing assembly on w-body .
    YouTube - Replacing Front Wheel Bearing Impala,Grand Prix (part 1 of 2
  9. #9 Re: 2000 GP wheel bearing
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    air chisel work well. Hit the hub before pulling the 3 back hub bolts she will pop off
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  10. #10 Re: 2000 GP wheel bearing
    SE Level Member blueGT00's Avatar
    Mason City,Iowa
    is there a metal shim/gasket that goes on before the hub??...maybe they consider it a dust shield??...i wasnt sure if there is supposed to be one or not...the one i took off didnt...
    '03 Chevy Silverado 1500 Blacked Out (My Truck)
    '00 Pontiac Grand Prix Gt (Fiancee's car)
    "you have to remember women are never wrong and they have the vagina."
  11. #11 Re: 2000 GP wheel bearing
    Michigan
    Yes blue the dust shield/spacer goes between the knuckle and the new hub with the notch set so that the ABS wire sensor can go through.
    Frank, make sure you get a Timken hub bearing, it is American made. Anything Chinese made will most likely fail quickly.
    Wife: Your car feels just like mine.
    Me thinking: You didn't step on the gas enough to feel the supercharger.
  12. #12 Re: 2000 GP wheel bearing
    Mason City,Iowa
    its on the rear btw...i kno the front has them what about the back?
  1. going on 4th Wheel Bearing
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 04:24 PM
  2. ABS wheel bearing/hub on non ABS car?
    By Captain Bravo in forum Brakes/Suspension/Chassis
    Last Post: 01-01-2011, 03:15 PM
  3. Possible bad wheel bearing?
    By Cail in forum General Tech Discussion
    Last Post: 09-01-2010, 12:32 PM
  4. 2000 GT wheel bearing question
    By c002529 in forum Brakes/Suspension/Chassis
    Last Post: 11-21-2009, 11:37 AM
