Thread: p0171 code, AEM WB reads good AFR
Results 1 to 3 of 3
  1. #1 p0171 code, AEM WB reads good AFR
    Apr 2009
    Lima, Oh
    I have a p0171 code that keeps popping back up. my wideband afr reads normal, not running lean. i just had my heads ported and polished at my local machine shop. they did a pretty good job and didnt open them up too much from what i could see. ive checked for vacuum leaks, nothing. i replaced my front o2 sensor, nothing. still have to try the egr tube. does anyone know if the ported heads could be causing this problem?
    2002 Black GTP, 3.2 pulley, CAI, Pacesetter Headers, 180 thermostat, xp cam, L32 rods, zzp pcm, N* TB, FWI
  2. #2 Re: p0171 code, AEM WB reads good AFR
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by JayGTP02 View Post
    You need to scan your Lft's Id be willing to bet there 16.4 Showing more then likely you have a vac leak
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: p0171 code, AEM WB reads good AFR
    Donating Users falconjohnd's Avatar
    Aug 2011
    new fairfield ct
    what am I looking for on my data? have 0171 and don't believe I have a leak
  1. code p0171 p0332 wont start now
    By juanathandavid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 05:29 PM
  2. Boost gauge reads zero
    By COEBAM in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:44 AM
  3. code P0171 keeps coming back
    By grandprix01 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-22-2009, 01:33 AM
  4. P0171 set on decel//update has another code
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2008, 11:59 PM
  5. No one reads the Please Read
    By IndeedSS in forum Off Topic Discussion
    Last Post: 12-28-2007, 02:56 PM
