Thread: key fob.
Results 1 to 6 of 6
  1. #1 key fob.
    GT Level Member wlmrt6's Avatar
    Sterling
    So my key fob will lock my car but not unlock it and ive tried a new battery. what the heck is wrong?
  2. #2 Re: key fob.
    GT Level Member 05CompG's Avatar
    Arizona
    Open the fob and check and see if the prongs that hold the battery in are still connected to the board...i was having a similar issue. My car would unlock but wouldnt lock or open the trunk and that was the issue.
    Her Name...Stacii Dash
  3. #3 Re: key fob.
    Nov 2009
    Grand haven
    This ^^^
  4. #4 Re: key fob.
    Sterling
    trunk and lock work but not unlock i will check and get back to you guys
  5. #5 Re: key fob.
    Sterling
    they are touching the battery.
  6. #6 Re: key fob.
    Arizona
    No not touching the battery, there are 3 spots where the metal that holds the battery in touches the circut board...if one of these three spots have a weak or broken connection, your fob wont work correctly...One spot is at the top and the other two are on the left and right sides. They are sautered(sp) to the board.
fob, key
