Thread: Car ramps
Results 1 to 13 of 13
  1. #1 Car ramps
    Donating Users
    NY
    Not sure if this is in the right section...I need to pick up some car ramps but I'm having trouble finding any that will fit given how low gp's apparently are (I'm at stock ride height btw). If any of you use ramps what kind do you use? I found some adjustable ones online but they're all in the $300 range and that's not gonna happen right now.
  2. #2 Re: Car ramps
    Charles City, IA
    Like the oil change ramps? Or you talkin trailer ramps?
    SMGPFC Two Nipple General
  3. #3 Re: Car ramps
    Donating Users
    NY
    Just for oil changes and light work under the car.
  4. #4 Re: Car ramps
    Brewcity, WI
    Welcome to RhinoRampsĀ®
    I picked a pair of these up at autozone, work perfect....and Im lowered also
    Self-denied SMGPFC member #1
    SEARCH works!
  5. #5 Re: Car ramps
    Charles City, IA
    I would really recommend a jack and stands, then you can take tires off and rotate them and do brake work.
  6. #6 Re: Car ramps
    Donating Users
    South Deerfield, MA
    I have ramps that the angled ramp part slides into the platform the tires sit on and can be removed from it if needed. This design allows the ramp part to pivot at different angles. I use a 2 foot piece of 2 x 12 under the angled part of the ramp so my car drives up on the 2 x 12 first then onto the ramp at a lower angle. It allows me to get more height than some of the low profile ramps and doesn't scrape the bottom of the nose on the ramps.
    This looks like the same ones I have:
    Heavy Duty Vehicle Service Ramps From Discount Ramps.Com
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  7. #7 Re: Car ramps
    '02 GTP oneil.GTP's Avatar
    Oct 2008
    Peoria, IL
    it'll take a couple more minutes to put the car up on jacks but they're so much more versatile for the same price if not cheaper.
  8. #8 Re: Car ramps
    if the car is still too low then use some 2x4s before them.
  9. #9 Re: Car ramps
    GT Level Member Vegas~Blown's Avatar
    Aug 2008
    vegas
    I've got both stands and RhinoRamps. the ramps are great for jobs that don't require the wheels to come off, obviously. I use 2*12s to lead onto the ramps for my lowered 98 (my stock '05 doesn't need them).
    Hell, I put the '98 on ramps sometimes for engine work just to save a little wear and tear on my back.
  10. #10 Re: Car ramps
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    My 06 wont go on my ramps. Plus you can just get so much more use outta a jack and some stands. You can get them so cheap these days
  11. #11 Re: Car ramps
    SE Level Member 4boostin's Avatar
    Feb 2010
    Utah
    Custom ramps....or poor mans lift
    Corvette C3 Ramps - Build Home Made Car Ramps
    98GS - 3" DP & Cat back, 9" K&N CIA in FW, Plog, 3.5", 180* Canned tune. 14.65 at 96.9mph, w/2.37 60ft. on G-Timer @ 4500 elev. @ 51*.
    87 Limited Turbo Regal- 12.04 @ 115 -Purchased New. Sold after 23 years and 115,000 miles
  12. #12 Re: Car ramps
    When I had a Prelude I picked up the lower Rhino Ramps and ... they fit under nearly every lowered car that comes into my garage.
  13. #13 Re: Car ramps
    Willoughby, Ohio
    jack stands x3, this way u wont have to worry about ride height or emptying your wallet
  1. Ramps for oil change/service?
    By nFavor in forum 5.3L V8 (LS4)
    Last Post: 02-11-2010, 08:21 PM
