Thread: Headlight capsule adjuster screw
Results 1 to 1 of 1
Threaded View
  1. #1 Headlight capsule adjuster screw
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    We have new used capsules and one of them is missing the adjuster screw. Is it possible to remove the screw from the old capsule and install on the new?
    Never mind. The big gray thumb screw looking thing is a plug with an oring. I assume this is a vent of some sort.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  1. Headlamp adjuster fix: [*]
    By BackInBlack in forum How To Write-Ups/Tech Tips
    Last Post: 05-12-2015, 09:31 PM
  2. Headlight questions
    By ABINOK in forum General Tech Discussion
    Last Post: 06-21-2008, 12:25 PM
  3. HeadLight Repair
    By Darkcelle in forum Off Topic Discussion
    Last Post: 05-23-2008, 09:49 AM
  4. Replaced pass. halfshaft - what did I screw up in the trans???
    By GTPrix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2008, 12:00 AM
