Thread: Ok UIM which is it!
Results 1 to 13 of 13
  1. #1 Ok UIM which is it!
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Advanced says the first but there stupid and have failed before.
    More Information for FEL-PRO MS95744
    FEL-PRO Part # MS95744
    Manufacturer Information
    CORTECO Part # 23757
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Ok UIM which is it!
    Omaha, NE
    To be honest, A LOT of RTV is better than a SC gasket. Do both the LIM and the base of the SC and make sure you don't block the holes in either.
    Its a much cheaper and stronger sealing option.
  3. #3 Re: Ok UIM which is it!
    Canton, Ohio
    Quote Originally Posted by chevyy1212 View Post
    ^^^this if for the l67
    ^^^this one is for an N/A 3800
  4. #4 Re: Ok UIM which is it!
    Oct 2008
    IL
    Yea Im just going to keep with the gaskets as I am pretty much just buying the parts and having it done so this is just my shopping list. Thanks tho for the extra option
    Quote Originally Posted by Wingman520 View Post
    Thanks for the help
  5. #5 Re: Ok UIM which is it!
    RTV is more difficult to clean up.
    If the paper gaskets are fresh-ish they should peel off in once piece.
  6. #6 Re: Ok UIM which is it!
    Charles City, IA
    I have never had a supercharger gasket not seal.
    SMGPFC Two Nipple General
  7. #7 Re: Ok UIM which is it!
    Clearly you've never used a garleak.
  8. #8 Re: Ok UIM which is it!
    Oct 2008
    IL
    Im using Felpro all around so Im not to worried about sealing issues.
  9. #9 Re: Ok UIM which is it!
    Canton, Ohio
    got two friends with gen V and use Felpro and have had no sealing issues and i'm not a fan of rtv anyway since it does take a bit to clean up and your welcome on the support lol
  10. #10 Re: Ok UIM which is it!
  11. #11 Re: Ok UIM which is it!
    Oct 2008
    IL
    You are the man as always. I hate anyone that lives close to you!
  12. #12 Re: Ok UIM which is it!
    You aren't alone, I hate them too.
    Yesterday a header install showed up, missing bolts, no o2 extension, Bonneville aka welding time, no WO2 bung plug, no W body trans dipstick tube. It's ok though..got on the highway and dusted him off.
  13. #13 Re: Ok UIM which is it!
    Canton, Ohio
    when do u need that dipstick tube? did two header installs (04 comp g and my 01 impala) and didn't have to have the bent dipstick at all
uim
