Thread: Which pulley should I get
Results 1 to 12 of 12
  1. #1 Which pulley should I get
    Tampa, FL
    I am on the fence with either getting a dynotune for 500 dollars or getting a 3800performance tune for 125.
    97 GTP: SD headers, Open cone, and a 180 Tstat should I get a 3.0 or 3.2 quick change pulley?
    Question 1. Can I do nothing else and be able to install a 3.0 pulley and get a custom tune or will I need more supporting mods like injectors, roller rockers, etc...?
    Question 2. Can I install a 3.2 pulley and get a 3800 performance can tune and be perfectly drivable?
    Question 3. Is 3800performance the best can tune out there? I heard ZZP is not a good one. Are there better ones out there?
    Thank you,
    Tim
  2. #2 Re: Which pulley should I get
    you dont have enough mods to run those, best you can get away with would be a 3.4 pulley.
  3. #3 Re: Which pulley should I get
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    x2 3.4 pulley. If you want to go lower your gonna need to cam or IC. For 500 dollars you can buy a tuner. Learning to tune is free.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  4. #4 Re: Which pulley should I get
    Feb 2008
    3.4 pulley with a local tune if possible.. save a ton of money
  5. #5 Re: Which pulley should I get
    Tampa, FL
    Can you explain why I need a cam. Or point me to what to search for or a link to an existing document. A 3.2 pulley just makes the blower spin faster. A cam does keep the valves open longer and a 3.2 might have diminishing returns but why not still put one on?
  6. #6 Re: Which pulley should I get
    Hagerstown,Md
    Quote Originally Posted by Tgranber View Post
  7. #7 Re: Which pulley should I get
    because youll be running too much boost (read: heat) and your car will be predetonating because of it. the KR levels you will see will be high and your car will run much slower and have the possibility of blowing up the bottom end than if you would have just run a better tune on less boost.
    here, read this thread:
    http://www.grandprixforums.net/safel...car-17482.html
    that will tell you the path you need to take to SAFELY mod your motor.
  8. #8 Re: Which pulley should I get
    you can run mid/high 13's on a 3.8 pulley granted you had headers, intake, and slicks.
    Smaller pulley just gives you more torque at 2500-4000 RPM, and no more top end.
    And top end is where you want power.
    Also your EGT's would be dangerously high risking the deadly chipped piston.
  9. #9 Re: Which pulley should I get
    Akron Ohio
    Step 1. Take pulley off 2. replace belt on shaft W/O pulley 3. 1-2 WOT runs 3.done
  10. #10 Re: Which pulley should I get
    MO
    Quote Originally Posted by JoshsGTP View Post
    two step 3's?
    <brandonl2000> LMAO D!!
  11. #11 Re: Which pulley should I get
    Jersey
    id do a 3.5
    16' wrx sti- stock
  12. #12 Re: Which pulley should I get
    Florida
    Lol...think he meant Step 4. Done...
    but then again youd be done on that 1-2 WOT runs so...i guess it works...
    Just get some awesome-o jet fuel, and run that setup without any pulley, it'd be awesome.
    But you need rather extensive mods to run a 3.0 pulley. A 3.2 can still run stock injectors, but you'll be super close to outflowing the injectors.
    Just get a 3.4 pulley, and some rockers, and get it tuned. you'll be plenty happy
