Thread: Sway bar broken
Results 1 to 13 of 13
  1. #1 Sway bar broken
    Dec 2010
    So, my 16 yr. old kid drove over a curb while turning a blind, sharp corner. Anyway, where the sway bar connects to the "rubber dampener" at the end of the bar, it broke. Well, no big deal to me since I'm not auto crossing this car - I'll just continue to drive. But now, I'm thinking about getting new tires for the car and begin to wonder if this would have any effect on my tire alignment. I'm thinking no but am not too sure. Any thoughts?
  2. #2 Re: Sway bar broken
    Charles City, IA
    no it wont affect it at all. If you just broke the link they are like $10.
    SMGPFC Two Nipple General
  3. #3 Re: Sway bar broken
    it wont, but it will make clunking noises.
    and you wont be able to get an alignment.
    and if you dont get one then you might not have any warranty on your tires.
  4. #4 Re: Sway bar broken
    GrandPrix Junkie
    St. Louis
    Perfect excuse for an upgraded sway bar IMHO. Get a Dorman front bar, new end links and get the alignment. Done, and your car will handle much better to help avoid those sneaky curbs that try to commit suicide by jumping out in front of moving vehicles
  5. #5 Re: Sway bar broken
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Hey i slid in the snow into a curb last week and had to get a the control arm sway bar and tie rod replaced
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  6. #6 Re: Sway bar broken
    Banned
    Mansfield, Ohio
    I got stock sway bars downstairs 70,000 miles perfectly fine if anyone needs them for cheap!
  7. #7 Re: Sway bar broken
    Michigan
    You may want to remove the stabilizer link so when you drive it it will not rub on your half shaft boot. The replacement for the stabilizer bar is heavier and shaped a little different, but is much better (I assume that this is a 1997 to 2003 GP).
  8. #8 Re: Sway bar broken
    Topeka, KS
    Don't all cars drive "Squirrelly" on the snow ?
  9. #9 Re: Sway bar broken
    Dec 2010
    Good point! But it is more "Squirrelly" than years past. We got 6-8" of snow last night and on my drive into work today my ass puckered up a few times when I hit some slippery patches. The car just drives different.
  10. #10 Re: Sway bar broken
    GT Level Member GtpKo's Avatar
    Best place on Earth
    My car (00 GTP) has the same broken sway bar issue. I have been driving it that way for a while. It's been 2 years since my last alignment so I'll have to fix it soon before I get another one. It will have to be fixed before a shop will do the alignment.
    As far as driveability, I have noticed some unstability while taking corners because without the sway bar the front suspension is more independent. In the snow, I have to take corners slower because it feels like the back end is gonna swing out suddenly so I know what you mean by squirrely.
    I had a '90 SE with horribly worn ball joints, that thing was so squirrely in the snow, I couldn't drive faster than 35 or it would spin out or something. Suspension is a safety issue, so it's up to you how long you want to drive it that way.
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  1. broken cam!
    By ks02sscamaro in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-16-2010, 06:18 PM
  2. broken inj clip...
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 04-01-2010, 07:51 AM
  3. How safe is it to drive with broken sway bar
    By blitz217 in forum Brakes/Suspension/Chassis
    Last Post: 12-09-2008, 01:28 PM
  4. HUD...Broken?
    By JCG's-GTP in forum General Tech Discussion
    Last Post: 06-27-2008, 12:33 AM
  5. Broken function
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:14 AM
