Thread: Misfire issue/question
Results 1 to 5 of 5
  1. #1 Misfire issue/question
    SE Level Member mousemonster1232's Avatar
    Surprise, AZ
    I am having an issue with misfires on a 1999 GP GTP.
    The parameters in which it happens (intermittent):
    -approx. 40-50 mph
    -cruising
    When it occurs:
    -when you gun it
    Basically if you are crusing at about 40-50mph, and then you gun it, it will misfire continuously for about 6-7 seconds if it is held down, but if you let go, give it a sec, and step back on it, it seems alright, but kind of laggy.
    I first thought the tranny wasn't downshifting, but now that it has occured more, I notice it definitely is misfires.
    I changed spark plugs just recently (within past month n half), so it should not be them. It isn't a highly modded car (yet) so I don't think it is a mod I have done either!
    Any suggestions will help!
    Thanks
  2. #2 Re: Misfire issue/question
    GT Level Member SlowRR's Avatar
    Brookfield, IL
    When you did your plugs did you change the wires? If not that's most likely going to solve the problem.
  3. #3 Re: Misfire issue/question
    Surprise, AZ
    Nope, I have not changed the wires, I was going to do that today, but idiots wrote my paycheck for two days after today, so I need to wait another two days.
  4. #4 Re: Misfire issue/question
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    check vacuum lines same thing to me. check for cracks
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  5. #5 Re: Misfire issue/question
    Surprise, AZ
    Quote Originally Posted by cliffdawg View Post
    Will do that as well. Just the ones on the top of the engine with the T things in it (MAF, S/C thing, and one other connection)? This car has already had those crack once before (not when I owned it though).
  1. misfire issue
    By SS98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2010, 09:12 PM
  2. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  3. misfire issue, out of town and no tools
    By Sandman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2010, 12:18 AM
  4. Need help with misfire 98 gtp!
    By Viperhunter in forum General Tech Discussion
    Last Post: 10-08-2009, 02:39 PM
  5. Question: Tranny Torque Converter lock/unlock issue
    By Lawngoose in forum General Tech Discussion
    Last Post: 05-31-2009, 09:54 PM
