can i get some comments on my build . click on the X!
Pictures by foursixer - Photobucket
Basically someone ran plugs in the holes so they didn't have coolant flowing into the blower case and throttle body.
On your picture 7of 7 what did they charge you to chafer it
Spraying post blower is actually a little better as long as it gets evenly distb.
use the edit button. its your friend.
so that explains one hole what is the second one for http://i1205.photobucket.com/albums/...IMG_2454-1.jpg
Len....
Pat's wrong on this one. That didn't come from me. He probably thinks I left the LIM on the engine, but the one on there was cut for the IC core and came off before you picked it up.
The early Gen V manifolds has the recessed area for coolant o-rings in the gasket (like a Gen 3 gasket) and the newer style of manifold had a flat top for the aluminum Gen V gasket.
Either way, I'd suggest drilling, tapping and using 1/4" npt plugs on the coolant ports. Then take off the side cover of the LIM and port out the coolant passage from rear to front.
hey bill, the coolant ports were already tap and thread. i can probably take some better pictures. am lost with your statement, "Then take off the side cover of the LIM and port out the coolant passage from rear to front". what side cover are you refering too? what generation is my LIM and how do i port the passage ways? is there a write up on this?
on the passenger side of the lower intake, there is a cap with two 10mm bolts. take that off and grind out some of the middle divider. this will allow more coolant to flow through that little section. the reason behind why you would do this is because when you close up the coolant ports going to the blower and throttle body you lose a marginal amount of flow to the rear head. to make up for it you open up the side of the lower intake coolant port a little.
make sense?
so, where the bolts are located is that the inlet leading toward the rear bank. do i have to port the outlet also then, if so where is the second area to be ported. but wait, if the coolant ports are already tapped and threaded, the port reference to bio might already been done. can anyone provide me a link to draw comparison.
