Thread: Electrically Stumped
Results 1 to 2 of 2
  1. #1 Electrically Stumped
    SE Level Member davis's Avatar
    texas
    Just joined site and need a little help. Wife comes home a month ago says, "abs light is on". We bought our GP new in 2000, so I get to looking around and find the abs ignition a/c clutch fuse blown under hood #28 I believe 10 amp. I replace it and start to back out and it blows again, needless to say it blows when it wants and i cannot duplicate when it blows. I have gone through a s load of fuses now. Symptoms abs light on, track light button will not do anything and a/c will not blow cold and power steering is a bit stiff, when you replace that little 10 amp fuse all is well. When I took it to the stealership and had the codes read, "it was replace both front hubs," done deal fuse keeps popping. Thanks for the help.
  2. #2 Re: Electrically Stumped
    check the wires that go to the abs sensors, they may be shorting out, they run along the lower control arm, and clip on the new hubs you just got installed.
  1. Stumped! need some help on this one!
    By Damon318 in forum General Tech Discussion
    Last Post: 11-04-2010, 11:30 AM
  2. Ok Im stumped...PLEASE HELP!!
    By sinceregtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2010, 06:27 PM
  3. Stumped
    By Vern in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2010, 10:45 AM
  4. stumped
    By lucidGTP307 in forum General Tech Discussion
    Last Post: 03-16-2009, 09:36 PM
  5. Stumped
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2009, 09:34 PM
