Thread: e85 and 65lbs injectors
Results 1 to 7 of 7
  1. #1 e85 and 65lbs injectors
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    switching to e85 and 65lbs injectors and have a question. i know your suppose to add about 30% more fuel for e85 but is that with the same injectors. since im doing both at the same time from stock injectors do i first factor in for the injectors then add 30% or just the 30%? if i have to factor for both does anyone have a % to add or take away instead of tuning twice?
  2. #2 Re: e85 and 65lbs injectors
    that is with the same injectors already dialed in for pump gas.
    scale your fueling for the injectors first, get it running, then add the 30% and fill 'er up. tune from there.
  3. #3 Re: e85 and 65lbs injectors
    Feb 2010
    somewhere cold
    thanks bio....bet she would have ran like crap with just the 30%. i figured but i had to be sure...do you know where to start when switching to the 65lbs injectors? with a full rebuild and a bunch of other mods im not guessing shes gonna start easy the first time as it is and would like to get her close as possible from the door
  4. #4 Re: e85 and 65lbs injectors
    im not sure about scaling injectors, but i can only assume you'd want to run a ration in comparison to stock. stock injectors are 33 lb.
    therefore, with 65 lb injectors that run much more fuel, you'd want to run (33/65)*(current values). makes sense to me, but i could be wrong. dont take my word for it.
  5. #5 Re: e85 and 65lbs injectors
    Feb 2010
    somewhere cold
    well thats no help...no "thanks" for you on that one bio although i do appreciate the response. your logic sounds reasonable but im assuming someone on here will have a def answer.
  6. #6 Re: e85 and 65lbs injectors
    Pennsylvania
    I'd say pm Tengis. He's the first that comes to mind with lots of e85 experience.
  7. #7 Re: e85 and 65lbs injectors
    Charles City, IA
    take (65/36)*your current values Then do a new maf tune.
    SMGPFC Two Nipple General
  1. Injectors
    By jdwyat in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2010, 01:00 PM
  2. 42.5# injectors?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2008, 02:17 PM
