Thread: Blower Motor Replacement
Results 1 to 5 of 5
  1. #1 Blower Motor Replacement
    indiana
    1999 GP with auto HVAC control has a blower motor with intermittent squeak (shrill). Are there indtruction that someone has on a step by step replacement for the blower motor. Also, best place to purchase cheap (130Kmiles).
  2. #2 Re: Blower Motor Replacement
    Charles City, IA
    Autozone or rock auto will be the cheapest. It is just like 4 7/32 bolts to take it out.
    SMGPFC Two Nipple General
  3. #3 Re: Blower Motor Replacement
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    learn how to bend or get somebody small and short my 6'3" ass had a hard time getting down there
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  4. #4 Re: Blower Motor Replacement
    moved..........
  5. #5 Re: Blower Motor Replacement
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    thanks to autozone i can remove my blower motor in like 4 minutes tops. im on my 3rd one right now. thank god for lifetime warrantys.
    just remove the panel thing on the passenger side floor. the one that'd be right above your feet, and the blower motor is right there. it has 3 screws. 2 of them you can see, 1 is hidden behind it. i recommend a power screw driver, a quarter in drive extension and u-joint, and..... i forget the socket size. remove, then unplug.
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  1. Blower motor resistor replacement
    By jake227 in forum General Tech Discussion
    Last Post: 03-09-2011, 05:14 PM
  2. Blower motor doesn't turn on - no signal to blower control module?
    By Joe942 in forum General Tech Discussion
    Last Post: 01-17-2011, 06:12 PM
  3. Blower motor replacement help!!!
    By blortz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-05-2010, 11:12 PM
  4. Blower motor OR blower motor resistor
    By DDK in forum General Tech Discussion
    Last Post: 06-01-2010, 07:38 AM
  5. blower motor resistor replacement
    By grandprixgt in forum General Tech Discussion
    Last Post: 06-27-2009, 04:00 AM
