Thread: No first gear, possible ECM issue?
Results 1 to 6 of 6
CoolDavid No first gear, possible ECM... 12-31-2010, 03:41 AM
gtpinsc Re: No first gear, possible... 12-31-2010, 06:59 AM
CoolDavid Re: No first gear, possible... 12-31-2010, 01:50 PM
gtpinsc Re: No first gear, possible... 12-31-2010, 02:32 PM
CoolDavid Re: No first gear, possible... 01-02-2011, 12:14 PM
gtpinsc Re: No first gear, possible... 01-02-2011, 03:04 PM
  1. #1 No first gear, possible ECM issue?
    Dec 2010
    A2
    Hey, I have a 1997 Pontiac Grandprix 2 door non-SC 3800 with 140,000 miles on it. I just had the typical no overdrive issue and had the transmission swapped out with a used one with 70,000 miles out of the exact same year model and engine. But right before the grandprix was in the shop for that, I also lost my 1st gear. If I move the selector to 1, the car does the same as if it were in 2 or D. I searched around on the web and some people had the same issue and either reflashed the ecu or swapped the ecu with one from a junk yard. Should that be my next step in trying to fix this problem? I can get the ecu out of the same GP that I got the transmission out of. But then I would have to mess with that GM passlock stuff right? Thank you
  2. #2 Re: No first gear, possible ECM issue?
    Jul 2008
    sumter,south carolina
    so it will not go in drive gear but will go in 1st or second? if so sounds like the forward band has taken a crap on ya.
    02 GTP with mods 05 GP for DD
  3. #3 Re: No first gear, possible ECM issue?
    Dec 2010
    A2
    It goes into drive no problem. Just when I press on the gas, no matter how high the rpms are, it will slowly speed up until 25ish mph then really take off.
    I went to the stealership for a reflash and they said it would be 85 bucks so id like to swap this ECU that I have. This whole passlock 1 process sucks tho.
    This post is exactly how mine is:
    http://www.grandprixforums.net/no-1s...pcm-34713.html
  4. #4 Re: No first gear, possible ECM issue?
    Jul 2008
    undo your battery for about an hour and see if that helps.. this resets the PCM. car will feel funny after u drive for the first time... this is the car relearning all its parameters. i have to ask is fluid level full? whens the last time since a filter change?
  5. #5 Re: No first gear, possible ECM issue?
    Dec 2010
    A2
    I reset pcm and all that and it still didnt help. Since I just had the transmission swap done, I also had them put in and new filter. So the filters about 4 days old. I did some driving to see whats going on. While in D, It seems like I only have 3rd gear because when I shift to "1", I do have 1st gear. When I shift to "2", there is no difference (no shift, rpm change). Then when I shift it to "3" it will shift. Then when I move it to "D", it will make no difference from 3, just the rpms will go up, no 4th gear or OD. Also when the car is in "D", its doesnt shift at all.
  6. #6 Re: No first gear, possible ECM issue?
    Jul 2008
    sounds like u lost 4th clutch... my guess is u bought a bad tranny.
  1. no first gear what gives
    By blacksleeper in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-11-2010, 07:49 PM
  2. No 1st or 4th gear
    By bhuff30 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-02-2010, 06:11 PM
  3. Strange 2nd gear issue/Scan Tool Advise
    By Higgins428 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:17 PM
  4. 2000 GTP 1st gear slip/bang issue
    By Progas in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-21-2008, 11:12 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
