Thread: 2000 GTP dies!
Results 1 to 12 of 12
  1. #1 2000 GTP dies!
    Clearfield
    I have a 2000 GTP and it dies intermittently, sometimes at the stop light and sometimes at 70 mph. I have had it in the shop with no luck, and I dont want to start throwing parts in it in hopes of finding a cure either (that can have a neg. effect on the wallet!) any help would be greatly appreciated!
  2. #2 Re: 2000 GTP dies!
    good chance your crank position sensor is starting to go out.
  3. #3 Re: 2000 GTP dies!
    Jul 2008
    sumter,south carolina
    ^ what he said... do rpms drop to 0 before it stalls?
    02 GTP with mods 05 GP for DD
  4. #4 Re: 2000 GTP dies!
    Clearfield
    I have'nt noticed the RPM's but I will try to catch it next time, but it is getting worse! died twice this morning and now takes longer to start back up! thx!
  5. #5 Re: 2000 GTP dies!
    GTX Level Member colindunn's Avatar
    Aurora, IL
    my friend had this problem on her car. her dad has owned grand prix's and pontiacs his whole life. he replaced the coil packs and that fixed it. something like that could vary and be many different things though.
  6. #6 Re: 2000 GTP dies!
    Brewcity, WI
    what about that fuel pump resistor thing?
    http://www.grandprixforums.net/fixin...lem-26549.html
    Self-denied SMGPFC member #1
    SEARCH works!
  7. #7 Re: 2000 GTP dies!
    SE Level Member NashGT02's Avatar
    Davenport, IA
    It could be a number of different things. I would start with your Crankshaft Position Sensor and then your ignition switch. My moms Regal GS had this issue and the first time was the Ignition switch the second was the Crank Sensor.
  8. #8 Re: 2000 GTP dies!
    Its not that small is it? DaytonaGTP's Avatar
    Nov 2009
    Michigantown, IN
    could be an ignition module. if they get too hot it shuts the car off and then you gotta wait for it to cool before starting it up again. also the module usually doenst throw a code. you should get a scanner to check for codes. even if the light is off it still might have codes. im also thinkin crank sensor but when mine was fubar i was still able to drive i just had no tach reading.
    2000 Daytona GTP(aka the slow fwd GTO)
  9. #9 Re: 2000 GTP dies!
    SE Level Member stlunatics2oo3's Avatar
    Michigan
    I agree with daytonaGTP ignition control module. I had an 89 cutlass that would intermittenly shut off while driving and it was that cost me like 90 bucks i think. autozone can test them I believe
  10. #10 Re: 2000 GTP dies!
    please post in the correct section
  11. #11 Re: 2000 GTP dies!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    CPS sensor.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  12. #12 Re: 2000 GTP dies!
    Clearfield
    The CPS seems to have been the culprit! thanks for all your help!
  1. 2000 dies while driving?
    By turbostang7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-04-2010, 11:20 AM
  2. 2000 Grand Prix Dies After Continious Running
    By Spk Stephen in forum General Tech Discussion
    Last Post: 03-10-2010, 12:29 AM
  3. Car Dies
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 04:14 PM
  4. 2000 3.8 gp dies
    By redrivergar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-05-2008, 07:07 PM
