Thread: lim gasket preperation
Results 1 to 19 of 19
  1. #1 lim gasket preperation
    GT Level Member gtcoup's Avatar
    Dec 2010
    plymouth ma
    So im gettin my list ready for this project. Let me add im broke as fcuk. I was lookin on autozone.com I know I know i should get them from the dealer blah, but I see some cheapos for like 40 bucks. if i can do this and get 50k ill be happy. whtas you guys in put on this Victor Reinz/Intake Manifold Gasket (MS16191) | Intake Manifold Gasket | 1997 Pontiac Grand Prix 6 Cylinders K 3.8L SFI OHV | AutoZone.com
    anyways this is what im prepared to buy
    lim gaskets
    upper plentum gasket
    oil change
    rad flush
    cooler tstat while im there
    injector o-rings
    coolant elbows
    seafoam
    please feel free to add anything i missed.... i know there are a bunch of threads on this topic, but often go into other things I just wanna be 100% sure im prepared for this
    Smgpfc
  2. #2 Re: lim gasket preperation
    Grand Rapids, MI
    well make sure you get the aluminum/metal LIM gaskets, putting in plastic is only asking for more problems down the road. also, only use fel-pro or gm LIM gaskets to ensure you don't have a leak.
    your grocery list looks pretty good other than the cheapo gasket. my advice, don't do it. i'd rather spend the money on a good gasket then spend a lot of money on a motor.
    also if you have the money, might as well do a new pcv valve just while you have the plenum off. i did that to mine when i did the LIM gaskets.
  3. #3 Re: lim gasket preperation
    Florida
    Yeah, spend another 10bucks on the Metal LIM gaskets, and do it right..
    Dont want to have to waste $40 on a failed plastic LIM gasket.
    Another good thing to do, is when you remove the coolant elbows, take a wire brush, or something to clean out the holes with, so theres no pieces of broken plastic in there.
  4. #4 Re: lim gasket preperation
    GT Level Member tdm571's Avatar
    Lakeside Park, KY
    What is the official part number for the Felpro aluminum LIM gaskets?
  5. #5 Re: lim gasket preperation
    Texas
    You need to add coolant o-rings(might come with LIM gasket) and black RTV to the list as well. Other than that looks good. If you are doing a seafoam treatment you might as well pickup a $4 TB gasket so you can remove the TB and clean the carbon buildup.
  6. #6 Re: lim gasket preperation
    Dec 2010
    plymouth ma
    ok well if i was to go cheap and get the 40$ set, what would i be looking at for the future? i mean like **** if i can get 30k off it and sell it i just need to make it till like august.... im just exploring my options here
    Smgpfc
  7. #7 Re: lim gasket preperation
    Grand Rapids, MI
    you will be looking at gaskets that leak again.
  8. #8 Re: lim gasket preperation
    St. Louis
    If you leave the stock thermostat in there it will be fine. Why drop a cooler one in? You could also leave the Seafoam off for now. That alone will net you enough money to get the proper LIM gaskets. Either get the alum. ones or don't do it at all IMHO. Those plastic ones may not make it to August and then you'll really be broke as fvck when you screw up the motor by spinning a bearing. Lets see, $40 LIM gaskets now or $500+ motor later. Have you even called a dealer to see what they want for a set? IIRC, they were only $45 last time I got a set. Check Rock Auto as well for good prices.
    And txslow6, not sure what you mean by "coolant o-rings", but the UIM gasket is all one piece, including the gasket area under the TB.
    You can still clean the TB w/o removing it and save yourself the $4 TB gasket. Just get some actual TB cleaner (there is a special cleaner for this that does not remove the special coating in the TB. DO NOT use carb/brake cleaner on it.
    And yes, black RTV is a MUST, as it must be used in all 4 corners of the LIM gaskets where the LIM meets the heads.
  9. #9 Re: lim gasket preperation
    Jersey
    small dots in all 4 corners of ur lifter valley, where the gaskets meet. Get extra oil, your going to want to wash down the lifter valley real well. Try to absorb as much coolant as u can,before lifting out the lim (with the L36 lim, its tricky to do). You will get coolant in the lifter valley. change the oil AFTER your motor is back together, and before you start the car, or do any type of cranking. Oil change should be the last thing u do. A 180* t-stat is a good idea.
    16' wrx sti- stock
  10. #10 Re: lim gasket preperation
    Jul 2008
    sumter,south carolina
    plastic gaskets will be ok if u do green coolant from my understanding.. hell i got 150k out of my plastic gasket in my old motor with dex cool. personally i would spend the extra dollars to get aluminum...
    02 GTP with mods 05 GP for DD
  11. #11 Re: lim gasket preperation
    My take on this and your brokeness
    Skip the T stat
    Skip the seafoam
    Skip Upper plenum gasket
    Skip the rad flush
    If you want to flush your rad, pull out your garden hose and flush. A t stat change helps modded supercharged cars. The only change you'd notice is a less efficient car/mpg. The plenum gasket is a big rubbery gasket, it's basically reuseable most of the time if you wipe it down. If yours is horrible, then replace it, otherwise reuse. Seafoam.. you don't need it, and if you did it..you should replace the plugs etc etc.
    Add 1 can of TB cleaner. The TB gasket is also reusable. Clean the TB well. I personally use Ultra Copper RTV, buy one tube and it's good for anything on the car, not oil only.
    The plastic gaskets should treat you decent for 50K, keep in mind that with the above savings, you could get the aluminums and not need to buy all this stuff again in 50K.
  12. #12 Re: lim gasket preperation
    Dec 2010
    plymouth ma
    theres the useful info i was looking for aluminum it is
    Smgpfc
  13. #13 Re: lim gasket preperation
    Quote Originally Posted by gtcoup View Post
    You live in Mass... I know they speak english up there. WUT?
    BTW don't forget some sealant on the LIM bolts
  14. #14 Re: lim gasket preperation
    Jul 2008
    theres the useful info i was looking for, aluminum it is.
    fixed.
  15. #15 Re: lim gasket preperation
    thought he was pulling a Yoda on us.
  16. #16 Re: lim gasket preperation
    Dec 2010
    plymouth ma
    thanks. sorry im just another high school drop out with bad puncuation.
    Smgpfc
  17. #17 Re: lim gasket preperation
    It's totally ok man.. I move fast and mispell a lot of stuff.... Just busting your chops Yoda...
    Your a bit of a drive from me, but if you need a hand getting this done. LMK... I've got the garage, tools etc etc.
  18. #18 Re: lim gasket preperation
    Dec 2010
    plymouth ma
    will do.
    Smgpfc
  19. #19 Re: lim gasket preperation
    Ottawa ON, Canada
    The problem isnt the coolant, its how often u change it.
    Dexool is supposed to have longer life but still only lasts so long, most people dont even flush there coolant and put new in and then it eats there gaskets and there internals. i wonder why...
    Green coolant will do the same if you dont flush it in the period of time its supposed to last.
    Ive talked to a few mechanics and im gonna keep the dexcool, but just flush it again before its recommended life span. So lets say its supposed to last 150,000km, il change it at 100,000-130,000km to be safe.
    Same with green coolant. but ive just heard when dexcool goes bad its bad lol.
    Although i did go with the aluminum LIM gaskets :P, makes sense. better quality.
    _______________________
    2002 Acura Rsx Type S - K20A2
  1. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
  2. GM Gasket Kit
    By Spartan GL in forum General Tech Discussion
    Last Post: 01-22-2010, 02:17 PM
  3. Gasket Help??
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2009, 02:21 PM
  4. gasket kit
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 04:39 PM
  5. Gasket Kit
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-23-2009, 01:09 PM
