Thread: Defrost Issue
Results 1 to 6 of 6
  1. #1 Defrost Issue
    GT Level Member GreyGhost's Avatar
    Nov 2009
    IL
    The car has extremely hot air and the fan works as it should, but the problem is it is not defrosting the side windows. What it is allowing is for moisture to build up on the windows and then freeze after the car is shut off.
    3 items in question are:
    Water pump
    Coolant
    Heater Core
    Is the heater core on these cars under the dash or engine side of the firewall?
    Yes, it could us a flush. I have needed to add a bit of anti freeze/ water, but replaced the cap and that took care of that issue.
    Anyone else ran across this issue? Had it in the past and that usually means a hole in the heater core, but with the water pump issues and purge issues that are listed haven't found anything where someone actually replaced the heater core.
  2. #2 Re: Defrost Issue
    Pennsylvania
    Before you shut your car off, turn it from defrost to blow at your face.
  3. #3 Re: Defrost Issue
    Waukesha, WI
    the heater core is under the dash, its not that bad to replace
  4. #4 Re: Defrost Issue
    Nov 2009
    IL
    Looks like just flushing it and seeing how much is in there is the best plan for now. It will be fun with it being 2 degrees out.
  5. #5 Re: Defrost Issue
    Nov 2009
    IL
    Blend door on these cars.......where is it located? Vac or mechanical controlled?
  6. #6 Re: Defrost Issue
    Nov 2009
    IL
    NM. Found this. http://www.grandprixforums.net/blend...ent-21941.html
    The defrost just doesnt seem to be hitting just the defrost, but is also going through the dash and foot vents. Anyone else run into this? Was replacing the door the resolution?
  1. 98 gtp w/ DCC will blow on defrost or vents but not floor-please help
    By Liquifire in forum General Tech Discussion
    Last Post: 08-03-2011, 06:07 PM
  2. Replies: 1
    Last Post: 02-01-2010, 10:18 AM
  3. A/C Turns on when i switch to defrost
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 08-29-2009, 10:51 PM
  4. Dual zone climate control - cannot switch modes (defrost only)
    By alacran in forum General Tech Discussion
    Last Post: 01-03-2009, 09:50 AM
  5. PM Issue
    By 04DetroitLS in forum Forum Bugs/Suggestions
    Last Post: 05-16-2008, 07:39 AM
