Thread: any how to's on replacing a/c compressor?
Results 1 to 5 of 5
  1. #1 any how to's on replacing a/c compressor?
    the desert
    1999 pontiac grand prix gtp thanks
  2. #2 Re: any how to's on replacing a/c compressor?
    Nov 2008
    Chicago
    Remove or Disconnect
    1. Recover refrigerant. Refer to "Refrigerant Recovery and Recycling, Adding Oil, Evacuating and Charging Procedures".
    2. Engine mount strut bracket right side.
    3. Electric cooling fan right side.
    4. Drive belt.
    5. Raise vehicle and suitably support.
    6. Right side engine splash shield.
    7. Electrical connector from the compressor.
    8. Compressor condenser hose assembly from the rear of the compressor.
    9. Rear compressor mounting bracket.
    10. Compressor mounting nuts.
    11. Compressor.
    12. Bracket with mounting bolts (if necessary).
    Install or Connect
    1. Bracket with mounting bolts (if removed).
    Tighten
    * Upper Bolt to 50 N.m (36 lb. ft.).
    * Lower Bolt to 80 N.m (59 lb. ft.).
    2. Compressor.
    3. Compressor mounting nuts.
    Tighten
    * Nuts to 100 N.m (74 lb. ft.).
    4. Rear compressor mounting bracket and bolts.
    Tighten
    * Bolts to 31 N.m (23 lb. ft.).
    5. Compressor condenser hose assembly to compressor with mounting nut. Using new sealing washers.
    Tighten
    * Nut to 33 N.m (24 lb. ft.).
    6. Compressor electrical connector.
    7. Right engine splash shield.
    8. Lower vehicle.
    9. Drive belt.
    10. Electric cooling fan right side.
    11. Engine mount strut bracket right side.
    12. Evacuate, recharge, and leak test system. Refer to Refrigerant Recovery and Recycling, Adding Oil, Evacuating and Charging Procedures.
    97 GTP Sedan: 3" from the downpipe to the mufflers, no cat, ADR 17's, AGX/Eibach, HAI w/k&n, 6k HID's
  3. #3 Re: any how to's on replacing a/c compressor?
    the desert
    thank you so much one more question can i fill the compressor with oil after it is installed or do i have to put the oil in the compressor before it is installed on the car?
  4. #4 Re: any how to's on replacing a/c compressor?
    Charles City, IA
    You put the oil in before you install it.
    SMGPFC Two Nipple General
  5. #5 Re: any how to's on replacing a/c compressor?
    Waukesha, WI
    when i did mine i did mine i didnt need to remove the fan, i got away with using a stubby wrench on the top nut of the compressor
  1. AC Compressor Kit
    By PrissiePantsGT in forum General Tech Discussion
    Last Post: 08-11-2010, 10:24 AM
  2. replacing bad ac compressor?
    By fst in forum Off Topic Discussion
    Last Post: 07-23-2010, 07:51 PM
  3. i need a new A/C compressor
    By foursixer in forum General Tech Discussion
    Last Post: 06-25-2010, 10:52 AM
  4. Compressor
    By InfidelRebel in forum General Tech Discussion
    Last Post: 08-13-2009, 01:41 AM
  5. How big of a compressor should I get?
    By FuglyGTP in forum Off Topic Discussion
    Last Post: 03-06-2009, 08:18 PM
