Is there a recommended way to clean fuel injectors while they are removed from the vehicle? I'm doing a top swap and want to make sure they are clean before I put new o-rings on and install them.
I thought it was recommended to use L67 injectors?
Maybe Im wrong?
You should install L67 injectors because of the extra fuel requirements that go along with being supercharged
Can you guys read?
He's asking how to clean them when they're off the car....
As far as i know, its not really possible without a specialized rig.
Ohm them out and hope for the best.
If you need one or two I have some that ohm'd out fine you can have. Other four I got were dead.
Just run some seafoam in the tank, or you can go to a shop that has a fuel system flusher.
