ok i need help with figuring out what is going on with my engine and how to fix it. whenever i mess around a bit use the gas alot this is what happens. i just put in a zzp pcm. i have a 3.35 pulley 160 t-stat autolite 103 racing plugs cold air intake cat,resinator,u-bend delete. my air fuel ratio quage reads rich when im heavy on the throttle. so im assuming this is causing the manifolds to heat up. what can i do to fix????
