Thread: Torque Spec for wheel bearing and Axle Nuts
Results 1 to 6 of 6
  1. #1 Torque Spec for wheel bearing and Axle Nuts
    Jul 2010
    Canada
    I was just wondering if anyone knew the Torque spec for the Wheel bearings 3 bolts and also if anyone knew the Axle nut Torque specs. I believe the Axle nut is supposed to be torqued to 118. Let me know.
  2. #2 Re: Torque Spec for wheel bearing and Axle Nuts
    Watch where you're posting.
  3. #3 Re: Torque Spec for wheel bearing and Axle Nuts
    None of them are important. German good'n'tight works well. for example when I put on an axle nut..it's til the air gun stops.
  4. #4 Re: Torque Spec for wheel bearing and Axle Nuts
    Charles City, IA
    sorry bill thats horrible advice for the axle nut. Torque spec for that on my 01 is 159ftlb. The back they just get them good and tight. The axle nut needs to be torqued or you will ruin the wheel bearing a lot faster.
    SMGPFC Two Nipple General
  5. #5 Re: Torque Spec for wheel bearing and Axle Nuts
    MD
    @TheOtherNick: True, true! See http://cds.activant.com/C2C/C01/35/192/157591741.pdf . Found this elsewhere on the forum. I am still looking for torque specs for the wheel bearing and caliper assembly bolts, besides "as tight as you can."
  6. #6 Re: Torque Spec for wheel bearing and Axle Nuts
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Nice job bumping a 4 year old thread, also the torque on those bolts is tight as you can just don't be stupid about it and break them.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  1. going on 4th Wheel Bearing
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 04:24 PM
  2. trans pan torque spec
    By 91gpse in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 11-26-2010, 10:28 PM
  3. Possible bad wheel bearing?
    By Cail in forum General Tech Discussion
    Last Post: 09-01-2010, 12:32 PM
  4. 20 Mimute Wheel Bearing......HA!
    By Lvgrandprix2003 in forum General Tech Discussion
    Last Post: 04-14-2010, 07:24 PM
  5. torque Spec's for front exhaust manifold?
    By luckyjack04GTP in forum General Tech Discussion
    Last Post: 05-30-2009, 12:29 PM
