Thread: TB Spacers
Results 1 to 9 of 9
  1. #1 TB Spacers
    Guys...
    I am guilty of not reading the how to mod your car etc recently. Is throw your TB spacer in the garbage before it causes a coolant leak in there?
    Do we have a post about which mods suck ass and should be avoided?
  2. #2 Re: TB Spacers
    Oct 2008
    Calgary, Alberta
    This is why I am glad that when I installed methanol injection I used the unused vacumme port in the back side of the tb.
  3. #3 Re: TB Spacers
    Nov 2009
    Grand haven
    This is a good spot or drill and tap a hole in the same area IIRC I am sure bio will chime in.
  4. #4 Re: TB Spacers
    we dont currently have a post specifically for things that we constantly shoot down. its a good idea, but itd need some definite reasoning, not just our opinions and a couple off base examples of what could happen.
    i tapped my blower case, which is what shawn i bet was referring to. ill post pictures later if it helps, but i cant do anything while im at work..
  5. #5 Re: TB Spacers
    I'm all for reasoning. TB spacers w/o the coolant ports blocked lat the lower are a common source of leaks as they block the flow of the coolant.
    Let's start listing them up and then those of us that have experience with them, can come up with valid reasoning behind the good/bad of them.
  6. #6 Re: TB Spacers
    bad mods (IMO):
    - throttle body spacers
    - anything less than a 180* thermostat (even 180* is pretty pointless, keep your heat and your 195* one)
    - OE-R lifters
    - phenolic spacers (blower spacer)
    - throttle body upgrades (unless beyond ~3.2 pulley or less)
    - cat backs
    thats all i got for now, all pretty self explanitory.
  7. #7 Re: TB Spacers
    Lightweight pushrods (Lighter weight and less strength)
    Fan switch harness (better to program temps into pcm, no dead battery and lower cost when getting a pcm)
  8. #8 Re: TB Spacers
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    bad mods (IMO):
    - OE-R lifters
    - cat backs
    hey all, im really considering doing the L26 UIM, but trying to go cheap on the spacer/adapter for the TB. I heard that the L26 doesnt route coolant to the TB, this true? also, will this suffice to get the L36 TB on the L26 mani?
    ZZ Performance
    or should i just get the dorman modified UIM with LIM gaskets from ZZP as well and call it a day?
    Last edited by popeyenate; 12-22-2010 at 06:10 PM. Reason: forgot to add something
  9. #9 Re: TB Spacers
    i actually liked having my caspers fan switch. i could turn it on high in traffic and keep my car cooler than i could driving highway speeds.
  1. What size spacers should I get
    By MrPoopyButthole in forum Visual/Body Modifications
    Last Post: 05-24-2010, 08:42 PM
  2. Wheel spacers?
    By PolishedandWaxed in forum Tires & Wheels
    Last Post: 02-15-2010, 07:17 PM
  3. ZZP Injector Spacers
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2009, 12:41 PM
  4. spacers?
    By crywolf in forum Tires & Wheels
    Last Post: 12-29-2008, 12:49 PM
