Thread: Transmission fluid is over full
Results 1 to 7 of 7
  1. #1 Transmission fluid is over full
    SE Level Member wadehosic's Avatar
    Firth, NE
    A month ago, my wife reported that our 97 GTP was "shifting different, kind of hard". So I checked the dipstick first and it was WAY over the full mark. I dropped the pan, put in a new filter, pumped some fluid through the cooler to make sure it wasn't plugged and then filled it back up the the full mark very carefully. Drove it for a while, made sure to go through all the gears and everything was fine. Yesterday my wife called to report the same symptoms again. I pulled the dipstick and it is way over full again! Anyone run into this before? I'm going to try to find a tran shop on Monday but is it even safe to drive to the shop? Should I have it towed?
    Thanks for any comments.
  2. #2 Re: Transmission fluid is over full
    Nov 2009
    Grand haven
    Maybe converter going bad just dumping the fluid back in the pan. I would send Trannyman a pm and ask him or click here Triple Edge Performance - Home Page and send him an email.
  3. #3 Re: Transmission fluid is over full
    Delaware, OH
    Ur not supposed to fill it when the trans is cold. Partially fill it then start the car and let it get up to temp and fill it the rest of the way
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  4. #4 Re: Transmission fluid is over full
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    your checking the fluid level with the car running correct? im not doubting your knowledge but its something that ive heard people pass up before and not realize it
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  5. #5 Re: Transmission fluid is over full
    Firth, NE
    Thanks for the thoughts, yes the tran was warm and the car was running when checking the level. It is so high that it is full of bubbles when running. It is not a "milkshake" as it would be if coolant was leaking into it. I'll send a note to Tranny man. Thanks.
  6. #6 Re: Transmission fluid is over full
    Nov 2009
    Grand haven
    NP.
  7. #7 Re: Transmission fluid is over full
    I'm thinking there may be a gasket (channel plate/VB) going that is causing some leaking and adding air to the fluid which would make it appear overfull and bubbly.
  1. transmission fluid
    By dave2002GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 09:01 PM
  2. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  3. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
  4. Transmission fluid change
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-06-2008, 03:42 PM
