Thread: Bad fuel mileage
Results 1 to 7 of 7
  1. #1 Bad fuel mileage
    GT Level Member Xorbex's Avatar
    Canada
    I havent measured properly and I will but..... It seems as though im getting 17mpg on a 05 gtp. Doesnt that seem a little low? New plugs and wires. Could a restrictive CAI possibly cause this also? I do have somewhat of a heavy foot but Im sure no more than the average person. I dont get into boost at every stop thats for sure.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: Bad fuel mileage
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Hey, where abouts in Canada?
    If you have poor fuel economy, I would first be looking at the air filter. Make sure its clean and in good shape. What kind of fuel are you running (brand and octane). When you installed the new plugs, did you gap them correctly?
    You could deff try Seafoaming the engine. Check/adjust your tire pressures...if your still running your winter tires, take them off, put your summers back on, I dont think we are going to see too much more snow.
    Jay
    (Ontario)
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  3. #3 Re: Bad fuel mileage
    London Ont, Canada
    I hope we never see any snow, but thats not happening lol
  4. #4 Re: Bad fuel mileage
    Canada
    NGK wires and Irridium plugs with proper gaps, winter tires are off and new tires have reccomended PSI within .5, air filter looks ok just may be an issues with restriction on the tubing. Thought about seafoam and have a can just dont know the proper procedure on doing it.... brake boother method, gas tank or oil.
  5. #5 Re: Bad fuel mileage
    Banned
    CT
    To be honest if you don't watch your driving at all, 17mpg average sounds about right. Some gas saving tips have been mentioned... additionally you can check to make sure the o2 sensors are working properly if you have a DHP, HPT or even an OBDII scanner. I wouldn't worry that anything is wrong until you either throw a code or distinctly smell unburnt fuel coming out of the exhaust.
  6. #6 Re: Bad fuel mileage
    I get about 17mpg in town driving so that sounds about right.
  7. #7 Re: Bad fuel mileage
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Im at 17-18 being very friendly to my GS. For real tho guys does spark plug gaps affect gas mileage that much. I know its needed for good performance but MPG's???
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  1. The alt rewire mod actually DOES increase fuel mileage!!
    By DanGTP in forum General Tech Discussion
    Last Post: 04-12-2012, 07:31 AM
  2. Fuel Mileage
    By Scheer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 10:57 PM
  3. 06 fuel mileage
    By 06 black prix in forum 04+ Specifics
    Last Post: 12-13-2009, 01:14 AM
  4. New Here, Fuel Mileage
    By cowmilker08 in forum General Tech Discussion
    Last Post: 04-13-2009, 04:24 PM
