Thread: DRL and HID Help
Results 1 to 12 of 12
  1. #1 DRL and HID Help
    Hamilton, NJ
    Hello everyone,
    I am looking to pick up some HIDs for my 05 GTP Comp G, however as I was doing some research I noticed that I may need to disable my DRLs to prevent any problems with the HID system. Can someone please help me out with figuring out how to do so? Any help would do thanks.
  2. #2 Re: DRL and HID Help
    Wichita
    I beleive there is a fuse for the DRL in the paenger side fusebox. Check your owners manual to be sure. All you need to do is remove that fuse to disable the DRL. Just dont forget you'll now have to manually turn your lights on
  3. #3 Re: DRL and HID Help
    Hamilton, NJ
    Now that wouldnt effect any other headlight functions correct?
  4. #4 Re: DRL and HID Help
    Wichita
    It will only affect the DRL. I've done this to my car. It works
  5. #5 Re: DRL and HID Help
    Windsor (ON) Canada
    I tried this on my 01" and got a nasty clicking sound (informing me that a fuse was "blown") I've heard there is some "extra" work to disable this on 01's.. this might also include 05's.
    ps.. Im getting my HID's for a christmas present so this info would also be appreciated.
  6. #6 Re: DRL and HID Help
    GTX Level Member bronzemist02's Avatar
    Canada
    ^ try disconnecting the heatsink inside the dash on drivers side. there is a pop out panel that is covering it right on the side of the dash. this worked for me.
    02 GT: Silverstar ultras, nighthawk platinum 2157s, ngk plugs, champion wires, 6k hid fogs, stainless magnaflows, cleaned tips, 2 10" subs. Finally painted.
  7. #7 Re: DRL and HID Help
    Florida
    ^^^ This. I've got HID lows and HID fogs, and I disabled my DRLs via disconnecting the physical connector on the drivers side. Just google "how to disable DRL in Grand Prix" or the like.
  8. #8 Re: DRL and HID Help
    Windsor (ON) Canada
    I already have that disconnected (pretty sure its the right part cuz it took me FOREVER to disconnected it)....maybe im missing something.. ill search
  9. #9 Re: DRL and HID Help
    Windsor (ON) Canada
    Just checked, and ya, I've had that blue and tan wire disconnected from that heatsink for a couple months now. exactly like this MACGP, so I guess I have my DRL's disconnected. Is there anyway to disable the auto headlights, like so I have manual control over them? (the only way I have been able to is to position the light switch in between side corner and headlight option) which is unreal annoying.
    Removing the DRL fuse results in a really fast annoying clicking sound.
  10. #10 Re: DRL and HID Help
    Windsor (ON) Canada
    Sorry to thread jack, and I hope the OP found his/her solution.
    Did some research and found out how to disable auto-lights for the 01-03 models.
    New England Pontiac Enthusiast Club :: View topic - HID question
    Has anyone done this..when I get a resistor I will be doing this ASAP.
  11. #11 Re: DRL and HID Help
    SE Level Member comengetit's Avatar
    New York
    I was reading up on this alittle and found out people were saying disable the auto lights too, because there unwanted and bad with HID's. Is this true...why would it be bad? your just using them alittle more.....so naturaly like anything else they wear more. is this true, do u need to disable the auto's? i dont see why unless you wanted to save that little bit of wear on the bulbs.
  12. #12 Re: DRL and HID Help
    Charles City, IA
    The DRL run on a lower voltage causing harm to the ballasts. The auto lights are fine you can keep those.
    SMGPFC Two Nipple General
drl, hid
