Thread: 1991 G.P SE 3.1 runs sluggish when cold??
Results 1 to 13 of 13
  1. #1 1991 G.P SE 3.1 runs sluggish when cold??
    SE Level Member mmarx's Avatar
    Dec 2010
    WI
    Hello, I have a 1991 GP 3.1, I recently replaced the Fuel Pump & Filter Proactively, and installed new Plugs and wires, new TPS and knock sensor
    also this summer. Now, when the Car is Cold, it has a very distinct Miss
    to it... until it warms up. I thought maybe the Fuel regulator might be bad,
    but checked the pressure and it's within tolerances. I sprayed Brake Clean
    around Intake Gasket/ Vacuum lines...Nothing. The Fuel Economy is really
    Bad, since the new Pump was installed. (15 mpg)
    It is not throwing a code out either??
    When it hesitates Cold, I can Mash her down, and it will take off.
    Any Ideas on what else it could be??
    (I checked the Temp sensor also.)
    It runs great, when warm!
    Thanks, Matt.
  2. #2 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    *INTRO PLEASE*
    hmmm interesting.
    do you mean like a miss fire when you say that it has a distinct miss?
    im wondering if theres something up with the injectors or if theres a blockage in the fuel line somewhere that would cause it to run that way. try fuel injector cleaner next
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  3. #3 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    Dec 2010
    WI
    I ran 2 Tank Fulls of Injector cleaner through it already.
    This Morning, when it was Cold, I sprayed it with Brake Clean,
    and there was No change again. (while running.) (Possible Vacuum leak?)
    I drove it and it ran Great!?
    I replaced the TPS, this Summer, with a cheap one from O Reilly's
    and I am wondering if this isn't the culprit?? (No Codes though.)
    I am thinking either it is a Intake Gasket leak or something with
    the TPS.?
  4. #4 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    Jul 2010
    Lansing IL
  5. #5 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    change the ECT sender.
    you said its only when cold and fine when warm...
  6. #6 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    Dec 2010
    WI
    If the Coolant Temp sensor was bad , wouldn't it through a code?
    "SES"
    There are no codes being thrown?
  7. #7 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    Mine didn't throw a code.
    Read low when at running temp.
    Car had misfires at idle. Ran great once warm.
    Now its smoother just by changing the ECT sender.
  8. #8 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    Dec 2010
    WI
    Thank You for that Information, Matt!
    When I get a Day off from Work, I'll try replacing it.
    I disconnected it, to Test it, and it sent a "15" code...
    so I thought that it wasn't the problem... but you are telling
    me that it might just be weak.
    I'll let ya know the results, when I replace it.
  9. #9 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    I dont think OBD lets you do this but with OBD II you can see what the PCM reads as the engine temperature.
    Mine was reading 4* to low. Misfired when cold as a result.
    If the car has a FPR i'd suggest putting vacuum on it. Although that would result in misfires regardless of running temp.
    Also does this vehicle have a vacuum advance?
  10. #10 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    Dec 2010
    WI
    Well, I replaced the Coolant temp. sensor, and it still
    runs like crap when Cold. :-(
    It doesn't throw a code.
  11. #11 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    SE Level Member trickytransam's Avatar
    Michigan
    Did you tap on your MAF when its acting up?
  12. #12 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    Dec 2010
    WI
    I'm wondering if a plugged Cat. could be my problem??
    It has the original Cat. on it.
  13. #13 Re: 1991 G.P SE 3.1 runs sluggish when cold??
    you could unbolt the downpipe and see how it runs.
  1. my car runs when its cold then dies
    By dstrow73 in forum General Tech Discussion
    Last Post: 09-15-2010, 12:42 PM
  2. 99 GTP runs fine cold, seems to lose a cylinder when up to temp?
    By 99GTPJay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 07:26 AM
  3. Sluggish
    By Mad Monkey in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-14-2010, 04:18 AM
  4. sluggish
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2009, 11:44 PM
