Thread: Fuel Gauge Problems
Results 1 to 10 of 10
  1. #1 Fuel Gauge Problems
    Tulsa, Oklahoma
    Mine is all wonky. Yes, that's a word. It never seems to be right. When it's almost empty, it shows full. When it's 1/2 full, it shows a random amount between empty and full. I have to judge my fuel by mileage. I hate this. Any ideas?
    Bastard Reptile's Avatar
    Kansas City, MO
    Simple....replace the sending module.
    Tulsa, Oklahoma
    and one would go about doing this by…? Sorry, I have no idea. I know how to change the fuel pumps on the 88(?)-96s, but not on this one. Is it close to the same?
    GTP Level Member TyroElite's Avatar
    Williamsport, PA
    Moved this thread to the body control with the rest of the fuel gage questions currently being asked.
    Kansas City, MO
    Replacing the module is pretty easy. If you open up your pass through, peel the carpet back you will see a little access door. It's got a few nuts that hold it down. Remove that, and it's right there. Unplug it, remove the expansion ring with a set of needle nose pliers, and the module will pop up out of the tank. Remove, Replace and Reverse the directions.
    Williamsport, PA
    If you do this... try and take some pictures and make a How-To for the site! Seems lots of people have this issue with the gauge.
    PA
    There is a similar thread here that you may want to read. I posted there about replacing the entire pump. It was easier for me to just pull out the entire pump assembly and replace it with a good used one from Ed Morad. And mine worked well up until I sold it.
    2001 GSE
  8. #8 Re: Fuel Gauge Problems
    GT Level Member Egleone6's Avatar
    Springfield, Illinois, United States
    Is there a part number?
    What is a Pass Through?
  9. #9 Re: Fuel Gauge Problems
    PA
    Quote Originally Posted by Egleone6 View Post
    Part number varies with your vehicle year and model.
    The pass through is the door that goes from your passenger compartment through the back seat and into the trunk.
    2001 GSE
  10. #10 Re: Fuel Gauge Problems
    Thanks.
    Is this usually the problem when you find the gauge not responding with the proper amount of fuel in the tank?
    I just know that on average, I get 20 miles to a gallon in town and that is 75% of my driving, that I can get 350 miles out of a tank. It has been shuffling a lot lately.
  1. Why Does My Gas Gauge Not Work?
    By BLACKEDOUTGTP in forum General Tech Discussion
    Last Post: 07-21-2024, 08:19 AM
  2. No fire on #3 cyl, injector problems??
    By gplostinnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 12:28 AM
  3. Trans problems.
    By my97gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 07:24 AM
