Thread: Pitting of aluminum parts
Results 1 to 4 of 4
  1. #1 Pitting of aluminum parts
    Looky what we have here:
    So I ground out the dull looking bits and filled it with an aluminum epoxy...
    Any relevance to coolant choice at all?
    Running 3-6 month old ethylene glycol at the moment. Flushed 20 gallons through the engine... ran it till the water came out just as clean as it went in.
    Only thing GPF brought up was coolant filters.... Which I have to admit is a pretty neat concept.
    Ford Mustang Tefba 1 1/4" Coolant Filter 64 1/2 - 73 - eBay (item 230524590357 end time Dec-09-10 07:46:15 PST)
    Did some "research" and came up with this:
    SpringerLink - Journal of Materials Science, Volume 42, Number 20
    Conclusions
    The composition of the oxide film formed on aluminum
    electrode in ethylene glycol–water solution depends on the
    existence of dissolved oxygen. In the presence of oxygen, a
    layer of aluminum oxide film forms on the aluminum
    surface to protect the substrate from corrosion. In the absence
    of oxygen, the film formed is mainly aluminumalcohol
    film that is less compact and less resistant to corrosion.
    The aluminum oxide film and aluminum-alcohol film
    have the different susceptibilities to chloride ion attack for
    pit initiation. There is a higher pitting susceptibility for
    aluminum oxide-covered electrode.
    The increase in temperature decreases the resistance of
    aluminum oxide film to corrosion reaction. However, the
    resistance to pitting corrosion increases.
    But that doesnt help me at all really... Also dont know if 3003 grade aluminum is even remotely close to what the S/C case is made of.
    According to this:
    Aluminium alloy - Wikipedia, the free encyclopedia
    3xxx's aren't used for ****... lol
    So i'm left with this question...
    What coolants (since no test will ever reveal what coolant is what..) would you recommend to help prevent pitting?
    And yes the $8 1 gallon jugs of coolant i've been buying say right on the label: "Low silicates. Aluminum compatible"
  2. #2 Re: Pitting of aluminum parts
    Hmmm That is a good question, but I really don't think there is one out there that doesn't do that.
  3. #3 Re: Pitting of aluminum parts
    Not even a hybrid OAT?
    Above repair fixed my coolant leak.
    For now...
  4. #4 Re: Pitting of aluminum parts
    Nov 2009
    Grand haven
    HMMMM good Idea.
  1. aluminum subframe
    By sdenton8 in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2010, 10:33 PM
  2. M90 is it aluminum?
    By JoshsGTP in forum General Tech Discussion
    Last Post: 07-03-2010, 12:27 PM
  3. Aluminum oil pan
    By quiksilvergt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-26-2008, 12:45 PM
  4. Pitting
    By GOINDEF in forum Tires & Wheels
    Last Post: 06-04-2008, 03:59 PM
