Thread: Misfire?
Results 1 to 6 of 6
  1. #1 Misfire?
    GTX Level Member blackflag's Avatar
    Virginia
    First of all I have an almost stock 2001 Gtp with 97k.
    So I just replaced my spark plugs (autolite 606's gapped to .56 per Nixon's advice) and wires (just basic parts store $35 WIRES).
    What a pain in the a$$, I guess hands are too big for this engine bay. next time im going to pull the engine forward. lol
    After everything was put back together It took 3 quick attempts to start. I put the scangauge on misfires and it read about 4 misfires in the first 30 secs. I shut the engine off popped the hood and checked all connections for a tight fit and everything felt good. It started first try after that but ran as high as 8 misfires. Turned off engine, turned back on and went on a test drive. No misfires.
    Am I all good?
    Btw
    -I did not reinstall metal sleeves.
    -I hand tightened plugs and then gave about 1/4 turn with wrench
  2. #2 Re: Misfire?
    Well what cylinders were the misfires on?
    And if they arent doing it anymore, then I dont know what to tell you. Because then its running good in my book.
  3. #3 Re: Misfire?
    Virginia
    Is there a way to tell without a check engine light? Is the scan gauge capable of that?
    Has anyone had issues for the first few mins after changing plugs/wires and it goes away?
    wtf
  4. #4 Re: Misfire?
    Virginia
    Just restarted the car. 22 misfires in less than 30 secs but the car seems to be running fine, No check engine lights.
  5. #5 Re: Misfire?
    Virginia
    just dug a little deeper into the scan gauge. Misfires are cyl 3 and mostly 4.
  6. #6 Re: Misfire?
    Virginia
    Disregard my freaking out. I guess not all$35 wires are created equal. Switched them out no problems
  1. Cyl 5 misfire. Tried everything
    By Kasey in forum General Tech Discussion
    Last Post: 10-10-2011, 06:16 AM
  2. 04 GTP misfire..a fun one..
    By silly34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2011, 11:42 AM
  3. 97 se misfire...please help
    By dei8fn in forum General Tech Discussion
    Last Post: 06-27-2010, 04:33 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. #5 Misfire
    By jjbskisail in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 02:36 PM
