Thread: How to do a coolant flush?
Results 1 to 19 of 19
  1. #1 How to do a coolant flush?
    Florida
    Can anyone tell me whats involved in doing a coolant flush?Im trying to save a potential $60,is there a how to? Like do I need just a fresh bottle of coolant and what else do I use?thanks
  2. #2 Re: How to do a coolant flush?
    Charles City, IA
    If a shop will do it for $60 just take it there. It will get a lot more out. Then just keep it fresh yourself.
    SMGPFC Two Nipple General
  3. #3 Re: How to do a coolant flush?
    Florida
    Ok, yea I dont wanna screw up anything and I dont mind too much paying $60 but just wanted to see if it was easy and I could save some dough.
  4. #4 Re: How to do a coolant flush?
    utah
    can you...yes. will it be as effective as theres...no
  5. #5 Re: How to do a coolant flush?
    Florida
    That makes sense.Now to keep it fresh,if I wanted to drain the coolant and add some fresh coolant where would I drain from?Ive heard coolant plug,radiator hose, thermo housing using a vac?which is best
  6. #6 Re: How to do a coolant flush?
    Charles City, IA
    Pull the lower hose.
  7. #7 Re: How to do a coolant flush?
    utah
    ^^that
  8. #8 Re: How to do a coolant flush?
    GTX Level Member cerick08GP's Avatar
    I know I’m going to start something here. Flushing a coolant system the “right” way is pretty involved, especially if your intent is to get away from Dexcool.
    However, just to help you out I have a quick ghetto method you can use. It is not really a flush but it is 1000% better than doing nothing.
    #1 Drain as much coolant as you can by removing the lower radiator hose.
    #2 Take a garden hose to the fill hole of your radiator and flush water through until all the chunks are out.
    #3 Reinstall the lower radiator hose.
    #4 Empty the coolant overflow bottle, and rinse it out.
    #5 Fill the radiator with 50/50 coolant, match what ever coolant is in the car. Especially if it is Dexcool, don’t cross the streams.
    #6 Fill the overflow bottle with 50/50 coolant to like 3-4 inches.
    #7 Button everything thing up and take a test drive.
    #8 Check the overflow bottle for proper level, add if needed.
    #9 Buy two cases of beer with the money you saved and have a house party.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  9. #9 Re: How to do a coolant flush?
    Florida
    ^ lmao.Good one man but I think ill pass and just get it done professionally, appreciate the input though.
  10. #10 Re: How to do a coolant flush?
    utah
    Dex cools the devil
  11. #11 Re: How to do a coolant flush?
    Florida
    Ohh I definately know.When I bought my car it had dex-cool then when i got my head gasket and valve spring replaced my mechanic replaced with the good ol green stuff.But my overflow has all the gunk and stuff,mad nasty.
  12. #12 Re: How to do a coolant flush?
    lol run water till all the chunks are out....
  13. #13 Re: How to do a coolant flush?
    Florida
    Just a quick update I cleaned my coolant resevoir as best as I could and also cleaned my radiator cap and tunnel because what I discovered.Can anyone tell me what is the "muddy paste-like" material that collects under the cap?It looks bad and hope it dosent signal internal mess.I also added more coolant,prestone.
  14. #14 Re: How to do a coolant flush?
    Charles City, IA
    Its dex cool sludge.
  15. #15 Re: How to do a coolant flush?
    Florida
    Oh wow I didnt think it could get that bad.Alright thanks.
  16. #16 Re: How to do a coolant flush?
    Run a coolant tee... but buy some 5/8ths hose so you can remove it when you're done flushing.
    20 gallons should be enough to ensure its clean.
    Garden hose has teh pressure. Pull the t-stat and run the engine with the rad cap in the "middle" position so it doesnt hold pressure in but forces it out the overflow hose.
  17. #17 Re: How to do a coolant flush?
    Florida
    So wait its ok if I run the engine with the thermo housing open? And whats a coolant tee,where does it go?Thanks
  18. #18 Re: How to do a coolant flush?
    you dont run it with the t-stat housing off, you run it without a t-stat
    It goes on the send line for the heater core.
  19. #19 Re: How to do a coolant flush?
    Florida
    oh i see.Thanks man
  1. Coolant Flush?
    By gahris in forum General Tech Discussion
    Last Post: 04-03-2010, 02:12 PM
  2. Coolant Flush twice?
    By nyydmb12 in forum 04+ Specifics
    Last Post: 02-14-2010, 08:17 PM
  3. did a coolant flush, the wrong way?
    By newgtpowner in forum General Tech Discussion
    Last Post: 10-12-2009, 04:20 PM
  4. Going to vip for a coolant flush
    Last Post: 03-12-2008, 03:42 AM
  5. Coolant Flush : How to?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-09-2008, 08:35 AM
