Thread: Coolant leak
Results 1 to 6 of 6
  1. #1 Coolant leak
    May 2008
    My 2001 Grand Prix is leaking coolant on the front driver side (end closest to headlight). Car seems to be alright when i drive but leaks a bunch of fluid when i shut the car off and stops not too long after it dumps a bunch.
    It is at the mechanic now but I want an idea of what this could be and roughly how much cash ill be out.
    Thanks
  2. #2 Re: Coolant leak
    Oklahoma
    From what you are describing, drivers side, close to the headlight, that sounds like an upper radiator hose, or I guess the bleeder valve could be loose or something. I cant imagine that costing a lot. Radiator hose is $30 or about there I believe.
    Let us know what they find.
  3. #3 Re: Coolant leak
    PA
    Actually, could be a number of things. Could be a radiator hose leaking. Could be the drain cock leaking. Could be radiator tank leaking.
    While he said by the headlight still could be the t-stat housing leaking. Could be the temp sending unit leaking. Could be the TB gasket leaking. Could be the bleed valve leaking.
    2001 GSE
  4. #4 Re: Coolant leak
    May 2008
    Thanks for letting me know some possibilities. Ill let you know what it ends up being. Hopefully nothing too expensive.
  5. #5 Re: Coolant leak
    May 2008
    Needs a new Rad.
  6. #6 Re: Coolant leak
    I live here. UR LOSN's Avatar
    Rockford, IL
    Ed Morad.....does wonders!
  1. Opinions on possible coolant leak
    By Sabrewings in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2008, 11:00 PM
  2. Weird Part and a coolant leak from it
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2008, 05:42 PM
  3. Finally found my vac leak... NOW WHAT??
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-07-2008, 02:32 PM
  4. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
  5. Oil leak problem
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 05:24 AM
