Thread: change cig lighter and aux power timeout
Results 1 to 7 of 7
  1. #1 change cig lighter and aux power timeout
    edmonton
    does anyone know how to change the lighter and spare power so that it does not timeout ten minutes after i shut the car off.
    the manual says go to the dealer.
    2003 grand prix gtp
    thanks
  2. #2 Re: change cig lighter and aux power timeout
    Charles City, IA
    Are you trying to disable it or what? If you want to disable it pull the rap fuse.
    SMGPFC Two Nipple General
  3. #3 Re: change cig lighter and aux power timeout
    edmonton
    not trying to disable it.
    trying to make it never shut off
  4. #4 Re: change cig lighter and aux power timeout
    edmonton
    trying to turn off battery rundown protection
  5. #5 Re: change cig lighter and aux power timeout
    you get one of them fuse adders and install it in the fuse box, to a constant power fuse, ( $3 test light helps find it fast) run wire to power port, this way you have a built in fuse for what ever you are powering.
    you will need to cut at least the hot wire off your power ports stock wire harness and cut and solider the new leads in, and use shrink tubing, it will last longer in the long run, better than the old cut splice and tape. you tube has some great vids to learn how to solider, its easy.
  6. #6 Re: change cig lighter and aux power timeout
    edmonton
    hmmm.
    thought there would be an easier solution.
    I also have a 01 oldsmobile aurora and all i had to the do was move the fuses to a different location...one slot over.
    maybe i'll check with the dealer...there has to be something preconfigured.
    thanks
  7. #7 Re: change cig lighter and aux power timeout
    Charles City, IA
    Just leave your key on?
  1. Cig lighter doesn't work! Please help.
    By jimintheb0x in forum General Tech Discussion
    Last Post: 07-26-2010, 01:00 AM
  2. Cigarette Lighter Fuse
    By matthew911 in forum General Tech Discussion
    Last Post: 04-06-2010, 10:35 PM
  3. Cigarette Lighter Problems
    By missyfisch in forum Audio, Security & Visual Electronics
    Last Post: 10-08-2009, 09:39 AM
  4. cig lighter
    By MizzBecca in forum General Tech Discussion
    Last Post: 07-12-2009, 11:08 PM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
