Thread: maintenance fun
Results 1 to 8 of 8
  1. #1 maintenance fun
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    I'm in the middle of replacing my transmission fluid and filter. Where do I pour the new fluid in at? Just wanna make sure so I don't mess anything up lol.
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  2. #2 Re: maintenance fun
    Portland Oregon
    Have to get a funnel and pour it in the transmission dip stick tube. It should take between 7.5 and 8 quarts on a pan drop/filter change. Make sure you put 4 quarts in first then start the car and add up to 7. Then shift all the way down on your shifter and back up though each gate and check your level to top it off.
  3. #3 Re: maintenance fun
    Dacula, GA
    Will do. Thank you good sir.
    R.I.P.
  4. #4 Re: maintenance fun
    Dacula, GA
    So how about when I tried to get the filter out I broke the little tube that it's attached by. I've been tugging on it and shiet to try and get it out but it just won't do it. Anyone have anything that could help? lol
    R.I.P.
  5. #5 Re: maintenance fun
    Denver
    If you're talking about the plastic neck that sticks into the transmission with an o-ring around it (typically), you can pull it out using a home made tool (basically a scratch awl with the tip bent back @ 115 degrees - you're making a hook basically).
  6. #6 Re: maintenance fun
    Dacula, GA
    I ended up getting it out. That was the biggest pain ever lol
    R.I.P.
  7. #7 Re: maintenance fun
    Charles City, IA
    punch and a hammer, split it in two then it will fall out.
    SMGPFC Two Nipple General
  8. #8 Re: maintenance fun
    you can only check the fluid when the tranny is warm and the car is level, in park and idling.
  1. Time for car maintenance
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-12-2010, 04:35 PM
  2. Car maintenance
    By ReaperRob in forum General Tech Discussion
    Last Post: 02-05-2010, 02:01 AM
  3. What happens when you dont keep up with maintenance?
    By FuglyGTP in forum General Tech Discussion
    Last Post: 03-03-2009, 06:32 PM
  4. Low maintenance mods.
    By bentendo92 in forum General Tech Discussion
    Last Post: 08-13-2008, 04:15 PM
  5. Genral maintenance on my 98 GTP?
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-23-2008, 04:56 PM
