Thread: running cold
Results 1 to 6 of 6
  1. #1 running cold
    Nov 2010
    ohio
    i have a 99 gtp with about 87000 miles i have driving for about an hour last night it was around 31 degrees outside my car never got over 170 degrees it was blowing heat out though
  2. #2 Re: running cold
    Charles City, IA
    Change your t-stat it is probably stuck open.
    SMGPFC Two Nipple General
  3. #3 Re: running cold
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    My car actually does the same thing, and I just recently changed my thermostat to a 180*. By recently, I mean like a month.
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  4. #4 Re: running cold
    HUDSON
    Mine does the same thing. It's not too cold here in FL (49) but with the heat on, and not sitting in traffic, it takes forever to warm up, but the heater is HOT.
  5. #5 Re: running cold
    Nov 2010
    ohio
    Yea I was thinkin the t stat was stuck open
  6. #6 Re: running cold
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    I was having the same thing, even threw a low coolant temp P code a couple times. Swapped out the t-stat for a new standard temp, rock solid 195's now.
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  1. Been Cold
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2010, 10:36 PM
  2. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  3. K&N Cold Air
    By juicestain100 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-04-2010, 04:11 PM
  4. hello from cold ny
    By ASCStinger in forum Introductions/Noob Questions
    Last Post: 01-11-2009, 12:33 PM
  5. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
